RollingRefrigerator
Eric
San Jose, CA
Foundation AWD CT, M3P, MYP
I gave Sheila Shine a shot this morning. The rain was heading in so I didn't get much time to do large sections, but I got some interesting results on a small section.
I also tried using those Mr Clean magic eraser pads on some water marks, fingerprints, and gunk. I found these to be great for a quick touch up here and there. No water needed, just give a waterspot or gunky area a quick scrub and it's gone. They didn't do much for fingerprints, though just kind of smeared them around.
Onto Shiela Shine. First I applied to a test patch by spraying onto a cloth per the instructions. It looked awful, honestly. Splotchy and darker and totally uneven. Yuck. See first pic for before (intentionally added hand smears first), and next two for after application.
But after letting it dry, I tried buffing it with a fresh rag moistened with water. This worked great, and returned the metal to its original look. 4th pic.
I assumed that just took the product off, but I did the fingerprint test and sure enough, it seems to prevent fingerprinting. See video comparing the Sheila side (first) to the untreated side.
Overall I'm encouraged, might be a good option to reduce fingerprints without coatings or wraps. But will have to wait for better weather to do the whole truck. I'm also unsure how long the effect will last, and if it's only a few days it's not going to be worth the effort.
Tesla Cybertruck Initial cleaning test results - Shiela Shine and Magic Eraser 20240217_080551
Tesla Cybertruck Initial cleaning test results - Shiela Shine and Magic Eraser 20240217_081127
Tesla Cybertruck Initial cleaning test results - Shiela Shine and Magic Eraser 20240217_081232
Tesla Cybertruck Initial cleaning test results - Shiela Shine and Magic Eraser 20240217_082108
Dazajj
James
Raleigh, NC
Lexus RX350
Regional Account Director
Will be interesting to see how long it lasts for sure! Thanks for the info!
Gigahorse
AWD
As someone who loves the SS look that Shiela Shine shows real promise!
Hope you will update us on how long the fingerprint protection lasts before needing to reapply.
Also since you are waiting to do the rest of the truck, any chance of you taking a fingerprint before AND after video on the same panel/spot? That would go a long way for comparison.
jasper7821
Ken
Tesla M3, Jaguar F-Type, Porsche Macan GTS, Indian
Aircraft researcher
You can go with these products... They clean up my appliances very well :)
I always used this stainless steel aerosol on my fridge and works good, but always have to wipe the floor in front of the fridge too.
I just tried the wipes and they’re 100 times better. Wipe and buff with the same wipe and I think it’s better than the aerosol, it seemed to prevent fingerprints better and they’re was no streaking at all.
amd they’re inexpensive too.
Tesla Cybertruck Initial cleaning test results - Shiela Shine and Magic Eraser IMG_1211
RollingRefrigerator
RollingRefrigerator
Eric
San Jose, CA
Great tip! Order placed, will try them out.
BeFamousVideo
Vincent
Orange County, CA
CT Beast delivered May 2024
Automation Agency
BeFamousVideo
Vincent
Orange County, CA
Automation Agency
@RollingRefrigerator thanks for your efforts to find a solution to maintaining the 30X stainless steel.
A query to ChatGPT-4 had the following results. I was particularly curious about the "protective coatings" mentioned and at the bottom are expanded options on coatings. One of the interesting options suggested is using Carnauba Wax to protect and reduce fingerprints.
ChatGPT-4:
For protecting 30X stainless steel, especially in applications like automotive panels where durability and appearance are crucial, there are several types of protective coatings that can be effective. These coatings not only enhance the material's resistance to environmental factors but also help maintain its aesthetic appeal over time. Here are some options:
Maintaining an exterior car surface made of 30X cold-rolled stainless steel, such as what's used in some high-profile electric vehicles, requires a careful selection of cleaners and preservatives to keep it looking its best. These materials need to clean effectively without damaging the stainless steel's surface and provide protection from the elements. Here are some recommended types of products and practices:
Cleaners
  1. Mild Dish Soap and Water: For regular cleaning, a solution of mild dish soap and water is effective and safe. It removes dirt and grime without harming the stainless steel surface.
  2. Specialized Stainless Steel Cleaners: Products specifically formulated for stainless steel can clean effectively while minimizing the risk of scratching or damaging the surface. They often contain ingredients that clean without leaving deposits.
Preservatives and Protectors
  1. Protective Coatings: Some products are designed to coat stainless steel, offering a layer of protection against fingerprints, water spots, and corrosion. These coatings can be particularly useful for outdoor or automotive applications where the metal is exposed to the elements.
  2. Carnauba Wax: A high-quality carnauba wax can provide a protective layer on stainless steel, enhancing its natural shine and protecting it from dirt and water. Unlike some polishes and waxes, carnauba wax doesn't leave a greasy or sticky residue, making it a good option for vehicle exteriors.
Practices
  • Regular Cleaning: Regularly removing dirt, grime, and contaminants is crucial for maintaining the appearance and integrity of stainless steel. This prevents buildup that could potentially damage the surface over time.
  • Gentle Tools: Use soft cloths or non-abrasive sponges to clean the surface. Avoid using steel wool or abrasive brushes that can scratch stainless steel.
  • Proper Drying: After washing or applying cleaners, thoroughly dry the stainless steel with a soft, clean cloth to prevent water spots and streaks.
  • Spot Testing: Before applying any new product, perform a spot test in an inconspicuous area to ensure it doesn't damage or discolor the steel.
More about protective coatings:
Ceramic Coatings
  • Ceramic Coatings: These are advanced protective finishes that bond with the stainless steel surface at a molecular level, offering a high degree of protection against corrosion, oxidation, UV rays, and even minor scratches. Ceramic coatings are known for their long-lasting durability and ease of cleaning.
Polymer Sealants
  • Polymer Sealants: These sealants form a protective layer over the steel, shielding it from moisture, salts, and pollutants. They can be easier to apply compared to ceramic coatings and often come in varieties that cater specifically to automotive use, providing a good balance between protection and gloss.
Clear Coats
  • Clear Coats: Automotive-grade clear coats can be applied to stainless steel to protect it from the elements while preserving its natural appearance. These coats are similar to what's used over car paint and can offer good protection against UV light and oxidation.
Metal Sealants
  • Metal Sealants: Some products are specifically designed to protect metal surfaces, including stainless steel. These sealants can help prevent corrosion and tarnishing by forming a barrier against environmental elements.
Carnauba Wax
  • Carnauba Wax: While not as durable as the other options mentioned, carnauba wax can provide a temporary protective layer that enhances the steel's appearance by adding depth to its shine and providing some water repellency. It needs more frequent application but is easier to apply and remove.
Choosing the Right Coating
When selecting a protective coating, consider the specific conditions the stainless steel will be exposed to, such as weather extremes, salt exposure (especially relevant in coastal areas), and the level of wear and tear expected. Also, think about the desired finish (matte, gloss, etc.) and how often you are willing to reapply the coating, as maintenance requirements can vary.
Remember, chatGPT doesn't 'know' things, it's just filling space so it looks like language you asked for. It's just a skilled "bullshitter". If its database doesn't have a match or bad advice in it, it'll make that up just as well as facts.
Derektsla
Derek
Greenville, SC
Cybertruck AWD, Model X
Entrepreneur
Let's please not hijack a useful thread by responding to this... "Hey everyone, let's talk about cleaning stainless..."
ideaXfactory
IdeaX
MO
Many trucks, and a Porsche
I've tried Carnauba Wax, but if thinking wax I would use Renaissance Wax instead. It certainly will work however perfect application can be a bit tricky.
