The Tesla Guy
- Daniel
- Mar 15, 2024
- Washington
- Website
- youtubeteslaguy.com
- 23MS Plaid, 23MY, LR,Order-FoundationCyberTruck DM
- Retired
Text from label
RENU CyberShield
Directions for use:
(Clean heavily saturated areas with RENU Waterless Wash before application)
Shake Well. Spray CyberShield directly onto a small section of the stainless steel surface,
microfiber towel or applicator pad. Working 1 panel at a time, gently spread product
evenly using a cross hatch motion. Allow product 15-20 seconds of dwell time for maximum adhesion to exterior surface. Once the product has been applied to the entire panel, use a separate, clean, and dry microfiber cloth to buff the surface using a circular motion. Continue this process, panel by panel, until the entire truck surace has been protected. For enhanced protection, you may apply a second coat of the product, following the same application and buffing process.
RENU CyberShield is a cutting-edge cleaning and protective solution that redefines the way you care for the exterior stainless surfaces of the Cyber Truck. This product is the result af a close partners hip between AutoRenu and Tesla, meticulously crafted to ensure the CyberTruck's stainless steel surface remains pristine and shielded from various contaminants, ensuring it looks as stunning as the day it rolled off the production line, RENU CyberShfeld is the epitome of innovation, combining cutting-edge cleaning technology with superior protective features. Preserve the allure of your stainless steel CyberTruck with this industry changing solution. Trust in AutoRenu's commitment to excellence, and let RENU CyberShield redefine your truck care experience.
Cleaning Features: Optimal Suds for Contaminate Encapsulation, Powerful Soil Penetration and Lifting Agents, Oil Stripping and Flash Optimizing Solvent, Addives for Optimal Stainless-Steel Cleaning, Chelating Agent for Light Iron & Fallout Residual Removal:
Watertion Features Invisible & Durable Barrier Against Oil, Soil, Soap Scum, and Hard water deposits, Self-Cleaning Properties, UV, fingerprint, Dirt, Oil, and Debris Protection, High Water and Oil Repellency.
First Aid Measures
WARNING: KEEP OUT OF REACH OF PETS & CHILDREN, MAY CAUSE EYE & SKIN IRRITATION.
Eyes: Flood with large amounts of water at least 20 min. get immediate medical attention if irritation persists. Can caus iritaston, redness, tearing, and blurred vision.
Skin: Flush exposed area with water, Remove all contaminated clothing Prolonged or repeated contact with water moderate irritation.
Inhalation:if affected, remove individual to fresh air. if breathing is dificult, administer oxygen. If breathing has stopped, give articial respiration. Keep person warm, calm
and get medical attention
Oral: If swallowed. Do not induce vomiting, get medical attention if symptoms occur and persist.
DEVELOPED FOR TESLA BY
AutoRenu
New Albany, IN
RENU CyberShield
Directions for use:
First Aid Measures
AutoRenu
New Albany, IN
