Snow rating on All Terrain Tires for Dual Motor Foundation Series Cybertruck?
What about tire compound? I'm most concerned about icy conditions. I assumed that 3peak would have the softer winter rater rubber compound, which would work better on ice, right?
Yes. Tho every brand's specific solution is slightly different.
swinefeaster
swinefeaster
Cybertruck Awd
So what do we know about the AT tires that come with the ct? Worse than blizzaks I bet right?
They don't appear to be winter-rated, no.
I think we have seen the Goodyear tires for the Cybertruck in two versions, one with the mountain peaks/snowflake logo, and one without. I don't remember where, but I swear I saw at least one of the Cybertruck reviews with video footage of the three peaks/snowflake symbol. But the image from the Tesla store for the spare clearly doesn't have the three peaks/snowflake logo.
Of course, neither are true winter tires because you can run both versions year-round.
Blizzak makes true winter tires. Of course, the icon does not mean it's a true winter tire (although all winter tires have the icon). Obviously, in winter conditions, a true winter Blizzak tire will outperform a tire that is not a true winter tire, even if it happens to have the three peaks/snowflake icon on the sidewall.
The situation in the U.S. was made uneccessarily confusing by those involved. I don't think an official designation for a true winter tire even exists. Instead, we get this mountain icon that even tires that are crappy in the snow and ice can legally display. The same logo is found on true winter tires that are exceptional in snow and ice, so there is no easy way for consumers to tell the difference between the two.
Sadly, the 3peak icon does not designate a true winter rubber compound, only that it has demonstrated the ability to accelerate 10% faster, on whatever winter surface standard use, than whatever baseline tire they use. It's a BS rating.
Got a source for that?
I'm actually curious. Getting tire stats that aren't based on 'feelings' lately has been tough. As far as I can tell, my four season winter rated tired drove about as poorly in the summer heat as I'd expect in the winter, and while I could feel the black ice under them coming down Siskiyou pass, I didn't actually slip. But then I stopped and waited for it to melt anyhow. Fog plus ice at dawn is just double unfun, I just took a nap instead.
Merle
Lake Tahoe
MS, 4Runner, Tundra, Lexus, R1200GSA, KTM, etc.
I live in a place where 3PMSF is enough.
Typically we get about 300" of snow, and temperatures that drop below freezing. It's not flat, so we have the need to grip as several of our roads exceed 6% grade (9% isn't unusual). You don't want to fight with chains because you could be dropping from 7300' down to a valley floor at 4200' where it's clear.
In addition, I've put on >30,000 miles in a year so using "spikes" or "studs" makes no sense. A dedicated winter tire will simply burn out as you head 200 miles in any direction, dramatically increasing wear due to the soft rubber compound.
So if you're looking for a long-distance tire, something that will handle most snow (R2/R3) chain conditions, plus get you out of a drive way so you can plow it, just get the 3PMSF tires.
Forecast this weekend ... Blizzard conditions, 4-8 feet of snow and 100 MPH wind gusts.
MyOtherTruck
Vermont
2020 G63, 2022 V60 Polestar, Ford F250HD, Cybrtrck
Anyone have any new info on options for snow tires?
CyberTruckeeTheOne
Andrew
Milpitas
4runner
Two days ago, had to stay one more night in Idaho Falls as there was a snow storm warning on my route.
I am pretty confident that CT can handle it with the standard-issue tires and all the anti-slip tech, etc.
But then the advisory said to bring extra food, water and thick blankets.
The one that gets me to reconsider was that it includes an ax. :eek:
Used to I-80 Truckee, Donner Summit and Yosemite in winter.
But that serious to advise to bring ax?:unsure:
So useful to break ice and fallen trees ^-^
Last summer when we were on CA 87 we got stopped for a fallen tree and had to dig out the machete and ax and (along with the other stopped drivers) took apart a tree that had blocked the road.
By the time the Hi-Po showed up, it was half gone, and by the time CalFire got there, we were driving away ^-^ Helped there was a Forest Service station not far away so one of their trucks was in the mix and had a chainsaw.
My winter kit contains a chainsaw, just not the summer one.
