Stainless steel is popping off
Mattkalin
Matt
SW Michigan
2023 F350 Superduty , 2023 Model Y AWD
Yes this has been a common issue. Open the frunk and there is a nut that is loose that holds this piece in place. Haven't had to do it on mine but seen this reported at least a dozen times.
Cyber_P
Alabama
AWD Cybertruck
Mine popped out too two weeks ago but had a SC appt. Gonna take it in again but they said "within spec" last time as it wasn't a specific spot, it was supposed to be to fix doors etc which are also within spec despite the lines not flush. Changing SC for next appt. Kennesaw leaves much to be desired.
Travis64
Travis64
NY
Tesla mp3 and awd cybertruck
Cant find it on forum or on truck
bigbangbadaboom
Tesla Model Y
DO IT NOW!
I didn't and didnt realize the bolt fell off and the entire a trim bent.
It requires a small torx wrench but tbh manually do it if you have to.
Remove the plastic frunk cover and you can peel back the rubber trim.
Common issue but I thought they fixed it with locitite
Gundo
Gundo
Connecticut
Porsche C2S
FYI on this front sail trim fix - it is secured with an 8mm bolt, not a torx
Best if you use a racheting open-end wrench to tighten. I used a flat blade screw driver to pry and hold interior trim away for access. No interior trim panels in funk need to be removed.
I can also confirm there is factory yellow Loctite on the threads. My but was loose, so I lossened it a bit more, added red Loctite to threads and tightened.
You can also realign the stainless sail trim while doing this to make it perfect if not already to your liking.
If you loosen the nut, be careful not to loosen too much and drop that nut into the body cavity!
Checked driver side too using same process and it was super tight.
When done, it lines up quite well indeed.
Tesla Cybertruck Stainless steel is popping off IMG_9161
Tesla Cybertruck Stainless steel is popping off IMG_9162
Tesla Cybertruck Stainless steel is popping off IMG_9164
Travis64
Travis64
NY
I cant see anything in there just going to take it to tesla
  • Haha
Reactions: igs
CT_AZ_4x4
Jay
Scottsdale, AZ
AWD CT
Self employed
Thank you for taking the time, it was helpful.
AlmostHuman
Earth
Model X, Cybertruck
Human
Passenger side panel had the same issue. Was easy to get a ratcheted wrench in without opening the front trunk. A decent flashlight you can see it behind the rubber by the windshield.
sharpgator
Scott
Birmingham, AL
26 AWD CT, M3
Thanks for this. I have one that is loosening up so I'm going to give it a try. I have an appointment at Kennesaw in October. From other comments in this thread, it doesn't sound like they will help me.
panthar
RS
Model Y , CyberTruck
Looking for something similar on the rear end of this piece (on top of rear seats) ... how to allign that ... want to fix it ...
Art138
Art
Weston,Florida
MYP,Ford GT & FS CYBERBEAST
Can you take a pic so we can see the area you are referring to? if it’s the piece I am thinking about it,may have adhesive.
