btcrealm
- Brian
- Aug 28, 2024
- Virginia-ish, USA
- Website
- btcrealm.com
- cybertruck
- NOC
And @Crissa there is a misconception here about how that happened. Apologies.Now that is definitely a factory problem. I'm going to geek out here.
Either :
1. The panel was not cleaned properly prior to bonding. [panel forming\stamping oil is thick gooey stuff - as it has to prevent mechanical damage to the panel when forming - it acts like a lubricant and a 'pad']
2. The panel was cleaned - but delayed too long prior to bonding.
3. The wrong bonding was used.
4. The right bonding, at the wrong external temperature & humidity. 'Cold Bond'
5. The right bonding, expired : has limited work time.
Tesla should step up - without issue and get this fixed. The question is: Can the repair center do this? Meaning is this bond in a 'caulking' tube or a 2-part which requires, mixing. [The tesla factory has this likely in 55 gallon drums with oxygen free or nitrogen filled dispensing systems]
..can they clean the panel properly for factory bond. Acetone: for example pulls water to the surface as it evaporates, more than 'dries'
Sorry man...let us know what they do.
Regards
This is due to a deer hitting my truck about 55 mph. I documented it in this thread here: cybertruck deer hit
What I am showing with this is that the 3M bonding tape will work in the trim cases as a temporary fix.
