Stripped steering wheel bolt - Advice needed 😞
HMGT3
Muscat, Oman.
Hi all,
I’m attempting to remove the steering wheel on my Cybertruck for a retrofit project, but I ran into a serious issue — the central retaining bolt is extremely tight, far beyond typical steering torque specs. Despite using the correct socket and breaker bar, the head rounded off (stripped) before the bolt broke loose.
At this point, I’m trying to figure out the safest and most effective way to proceed without damaging the steering column, clock spring, or any of the steering wheel electronics.
A few questions for anyone who’s dealt with this:
Did you have to apply heat to release the Loctite? If so, how much heat (temperature range or duration) and exactly where did you apply it — the bolt head, hub area, or shaft?
Is there a specific extractor socket or left-hand drill bit that worked for you in this confined area?
Any risk of damaging internal sensors or airbag wiring with localized heat?
Would it help to pre-soak with penetrating fluid, or is Loctite too resistant for that to make a difference?
I’m working on this as a DIY job (no Tesla service centers here in Oman), so I’d really appreciate any first-hand experience or technical insight before I try heat or extraction methods.
Thanks in advance — any input from those who’ve removed or replaced their Cybertruck steering wheel bolts would be incredibly helpful.
Tesla Cybertruck Stripped steering wheel bolt - Advice needed  😞 IMG_0518
ABILISK
DFW
ts.la
‘24 Beast
No experience with this specifically, but I’ve had to extract my fair share of bolts in my time. First and foremost, sanity check yourself in the EPC that it’s normal thread. Then I’d heat gun that thing like crazy. You’ll definitely need a set of extracting drill bits at this point. You use a normal drill bit and drill a pilot hole then extract the bolt with the other bit.
MAKE SURE your bits are rated for what you’re trying to extract. From your photo, looks like they used an 8.8-grade bolt in there. These bits should work: https://www.amazon.com/Removal-HighSpeed-Extractor-Toughness-8-8-12-9/dp/B0CYN2DFCX
Yes, I’ve broken an extractor inside my pilot hole before and ended up worse off than before. It was a bad day. Good luck!
That Beast Mode
Phil
New Jersey
Breaking an extractor inside the pilot will make a grown man cry, and it's always the last bolt you need to remove to finish the job - ALWAYS. Same as Abilisk, no experience with this exact scenario but I've removed many broken bolts (and knuckle skin). Before going the extractor route, I'd try also heat gunning the shit out of it and hammer a just slightly larger hex bit or even a star bit in there to see if you can get it to bite, with the heat it might be enough to crack it loose, if not you're in the same position and need the extractor. Also, like he said, make sure it's not a reverse thread.
HMGT3
HMGT3
Muscat, Oman.
Thanks so much for the detailed advice really appreciate it. I’ve ordered a proper set of extractors rated for these bolts, I’d hate to snap one inside. Definitely don’t want to make things worse!
Sturdybirdy
Jesse
NorCal
18 Ford f150, 24 Model Y, Cybertruck
Self Employed
I second what Abilisk and That Beast Mode said, especially the part about trying to tap in a slightly larger hex or star bit. I would even measure to the bottom of the socket hole, then put a depth line on whatever bit you're using (if the bottom of the hole is 1/4" then make a mark or line 1/4" from the end of your bit), so you know you're at the bottom of the hole and not just at the surface, where it's much more likely to strip more. Good luck! Where there's a will, there's a way.
PungoteagueDave
Boynton Beach
You can also cut a slot across the head using a dremel cutting wheel. It would create a mess, so use a big towel over everything. You can control the size of the slot to match a hardened driver bit on a long handle breaker bar. Heat could be a mistake in this situation unless you can heat the surrounding metal more than the bolt, as a heated bolt will expand. Heat is often helpful where the device being removed can be heated more that the bolt or screw. For example, heat helps removed frozen nuts because they can be heated more than the bolt.
CT_AZ_4x4
Jay
Scottsdale, AZ
AWD CT
Self employed
Be careful to ensure the slot halves the bolt head as perfectly as possible. Too far to either side and that section can break off when force is applied. Ask me how I know. Then, attempting to tap it is nearly impossible because the bolt’s top is a divot leading any tap or drill into the threaded side of what the bolt is threaded into. Good luck!
There is a thread sealant integrated onto the bolt, which is probably why the service guide calls for it to be discarded and replaced.
Maybe heat will help loosen the sealant, but none of the Tesla service guides call for it, or suggest the bolt will be difficult. The interwebs, on the other hand, are replete with sad tales of busted knuckles, stripped bolts and loud cursing while attempting this procedure.
Next best bet: impact wrench. Just don't collapse the steering column lol
Planet Earth
$59k CT delivered 6/26/26
Try tightening first and then loosening. I am still struggling to understand how a grade 8 bolt head was rounded off.
The sandpaper/smaller diameter socket hack would be my Plan A to remove the rounded bolt.
Best of luck!
Should have used an impact driver like a pro would have.
Also, cheap bits seem more common than ever. A few decades ago, "tool steel" used to mean something!
Professor
Robert
NorCal
www.roberthawthorne.net
Cybertruck Foundation Series AWD, Ducati ST2
Theatre Technician
Just thinking out loud here - there's no way it's a reverse thread is there?
I read the Tesla Cybertruck wheel removal instructions and it doesn't specify.
Just seems odd that you were able to round-off a grade 8.8 hex bolt...
I removed mine. Definitely Right hand thread. Haven't found a leftie yet. And yeah its breaker bar tight.
I'd say tighter than most lug nuts. totally unnecessary as the shaft is spined and keyed.
Or you could take it to the SC and say, “I don’t know how this happened” .
People tell me that about foreign bodies up the butt all the time.
Sorry…terrible time for humor.
Hurts my soul to read this.
neights
San Diego, CA
2024 CT AWD, 2023 MY LR, 2012 Lotus Evora S, 2006 Yamaha R6 Trackbike
Architect
It looks like maybe there is still good hex pattern in the lower portion to get bite. Before drilling out maybe try again with the breaker bar but ensure that the torque is applied at the correct angle not to pull the bit at an angle, and move very smoothly. I would use heat to loosen the threadlocker as suggested as well. Good luck!
