Tesla Refuses to Work on Vehicles With non-OEM Tires
DAE1
DAE1
Southern California
CyberBeast & Model S 85D
I was planning on purchasing non-OEM tires for my CB as I hear they burn through tires every 6K miles, however, I recently discovered that Tesla refuses to work on vehicles with tires that they don’t personally certify, even when the sizing, speed rating, etc. is the same. Has anyone else heard of this? They refused to work on my Model S because I have Bridgestone tires (exact same specs as OEM). They called them “after market” as though they were modified but they are not.
Tesla Cybertruck Tesla Refuses to Work on Vehicles With non-OEM Tires IMG_3050
Update: to add more context, service request was because the front driver’s side tire (one of four) was rubbing the fender when the steering wheel was turned. Vehicle has OEM wheels. Issue was later determined to be a worn bushing on a lower control arm.
I'm pretty sure that there's more to this story than non-OEM tires. I suspect that in this case, there was non-OEM wheels and that the Service Request was for something with the wheels.
There have been hundreds of thousands or maybe millions of Teslas with non-OEM tires installed, and AFAIK, Service has never rejected one.
Even Tesla recommends to go to Discount Tire these days for tire issues.
So, for tires, as long as they are just standard types, I'd expect no problems. But change the wheels out and add spacers and expect Tesla to work on the brakes, that may be a different thing.
SCTesla
22 Model S, 24 CT
Try again or try another SC. This isn't normal and it seems like this person is an idiot, unless the issue is with the tire/wheel.
I've always had different tire types on my Teslas and no one at Tesla has ever said a thing.
SCTesla
22 Model S, 24 CT
Agreed.
jf64k
Never had an issue with my 2020 MYLR with Vossen 19" and OEM tires, then Vossen 21" with oversized Michelin tires.
But the service requests had nothing to do with tires/wheels. So??
igs
CT, MX, MY
Google right to repair.
Yeah, need more context for this one.
igs
CT, MX, MY
mcorf
Campbell,Ohio
2021 LRAWD Model Y. 2024 LRAWD Model 3. 2024 Foundation Series Cybertruck AWD.
I've used Michelin, Continental, Vredestein, and Goodyear on my vehicles over the past 5 years on my vehicles and they have never given me any problems.
DAE1
DAE1
DAE1
Southern California
No, these are the standard wheels.
But yes to the repair having to do with tires/wheels as the fender and front drivers side wheel were rubbing. Had to take it elsewhere and found that the lower control arm had worn bushings causing the entire arm/ wheel to shift about an inch or so forward and backward.
