WARNING - Possible dangerous chemical in Barkeepers Friend
Vladimer
Steve
Virginia
2024 FS CB, 2018 MS 100D
Dang spammy site/article - following the latest traditions of alarmist writings lest nobody clicks it. No references but it did reveal an important little nugget:
"Other health factors such as alcohol consumption and obesity-related liver fat accumulation did not seem to contribute to significant liver fibrosis when PCE was detected in the blood."
Which clearly means that one must use alcohol with barkeepers friend (hey why else is this called BAR-keepers friend). So grab a six pack and start polishing...
My truck is wrapped but, based upon the erudite wisdom of Yohst, Imma grab some beverage and get to work!
Rhineg
Geoff
Near Philly, PA
2024 Cybertruck
Hi - briefly looked up and thought it was important enough to let my cyber bros know :
see article below and it seems Barkeepers Friend - which I absolutely love - may have this chemical… liver issues possible
https://www.foxnews.com/health/comm...spike-liver-disease-across-us-researchers-say
I suppose ventilation and gloves are in order - please consider them during cleaning
Not really good for your Stainless either pH 1.5 to 2.5. Link to MSDS => https://www.barkeepersfriend.com/wp-content/uploads/2014/12/SDS_BKF_Cleanser_Polish_6-12-15.pdf
BrockN
Brock
Kamloops BC Canada
Rhineg
Geoff
Near Philly, PA
2024 Cybertruck
Good input, but rail dust and initial passivation is an upfront event and not necessarily to be repeated. One good thing is that it does NOT contain clorides.
Metallic brake pads scatter ferrous dust along roadways, and rail dust can carry in the wind along with other contaminants.
Repeated passivization may be needed after an abrasive cleaning.
It's not necessary to use BKF or other acidic cleaners on a regular basis, but acids are not really harmful to stainless steel, and are actually recommended for addressing surface contamination.
"While wearing gloves, apply a mild, citric acid cleaner with a sponge or microfiber cloth to evenly saturate the entire area of the stainless-steel panel. Tesla recommends CitriSurf® 77 or equivalent. The citric acid binds to and dissolves the iron oxide in the contamination, which can then be removed from the stainless-steel panel."
https://service.tesla.com/docs/Publ...UID-E37F1326-EB87-4D02-9007-7034DB54C604.html
BrockN
Brock
Kamloops BC Canada
I beg to differ on the need to repeat. Where I am, calcium chloride is used to keep the dust down. The result is splatter on the truck that is very hygroscopic. That means any iron that hits the truck flash rusts. Not treating those spots can result in pitting of the stainless. So when I see that happening, I have to wash the truck and remove the rust with BKF before it damages the stainless. The citric acid in BKF serves to passivate any areas that the natural chromium oxide has been removed or damaged.
it's too much work to do unless I see a clear need, but using BKF shouldn't be a problem, even according to Tesla.
