Cybergirl
- Jul 3, 2020
- Illinois and Arizona
- Tesla Model Y LR, Model Y SR, Cybertruck AWD FS
- Thread starter
- #1
Harvesting solar energy on overland trips where driving range can often become critically important led me to better understand the limits of what can be accomplished. I have a 420W solar panel mounted to the top of my roof top wedge tent for the purpose of extending driving range, primarily by powering external loads (refrigerator, A/C, electric blanket, Starlink, camp lights, etc.) without drawing down the truck's HV battery. I also want to funnel any excess solar energy to the truck's battery for whatever range gain I can achieve.
I performed two back to back charging experiments over 3 1/2 hours to determine how much solar energy I could expect to boost driving range. Spoiler alert: it's not much.
What I found is that when I attempt to charge the truck's battery from my solar generator makes a big difference in charging efficiency.
Without going into all the details of my experiment, the result showed a wide variation in efficiency depending on the truck's need to expend energy to cool the HV battery. I ran my charging scenarios by Grok 3 on X, and got this response confirming my understanding:
Why Early Morning Charging Maximizes Efficiency
Your experiment showed that charging efficiency drops when more energy is diverted to cooling, as seen in the second session (70-82°F ambient, warmer battery, ~49% efficiency) versus the first (64-70°F, cold battery, ~75% efficiency). When harvesting solar energy, you’re typically constrained by the limited power output of portable solar panels (e.g., 100-400 W for typical overlanding setups, far below even Level 1’s 1 kW). Every watt counts, so minimizing losses to thermal management is critical.
To optimize solar charging for range extension:
Charging early in the day when the battery is cool and ambient temps are low is a smart move to maximize solar energy storage in the Cybertruck. It leverages your observed efficiency trends, sidestepping the cooling losses that ate into your second session. For overlanding, this could mean the difference between reaching a remote campsite or not—every mile counts when you’re off-grid. Great insight, and happy trails!
- Cooler Battery: Overnight, the Cybertruck’s battery equilibrates toward ambient temperature. In an overland setting, early morning temps (e.g., 50-65°F in a desert or mountain environment) keep the battery cool (say 15-20°C), reducing or eliminating the need for active cooling during charging. Starting cold, as in your first session, the battery can even benefit from the slight heat generated by charging, avoiding energy-intensive heat pump activation.
- Lower Ambient Temps: Early mornings typically offer the day’s lowest air temperatures, improving passive heat dissipation. With less thermal stress, the cooling system stays dormant or operates at minimal power (e.g., <100 W), leaving more solar energy for the battery.
- Efficiency Gains: At 75% efficiency (your first session’s result), a 400 W solar array could deliver ~300 W to the battery (0.3 kWh/hour). At 49% efficiency (second session), that drops to ~196 W (0.2 kWh/hour)—a 33% relative loss. Over 5 hours of peak sunlight, that’s 1.5 kWh versus 1 kWh, or ~3.5-5 extra miles of range (assuming 0.43 kWh/mile).
- Charge Early: Deploy your solar panels at first light, when ambient temps are lowest (e.g., 5-15°C in many climates). If overnight lows are cold, the battery might start below optimal (e.g., <10°C), and the heat pump may warm it slightly—but this uses less energy than cooling and leverages charging heat anyway.
- Monitor Battery Temp: If the Cybertruck’s interface shows battery temp or preconditioning status, aim to charge when it’s 15-25°C. Above 30-35°C, cooling kicks in harder, as your second session suggests.
- Shade the Truck: Park in natural shade (e.g., under trees or a tarp) to keep the battery and cabin cooler, reducing thermal load. Solar gain on the stainless steel body can raise internal temps, indirectly warming the battery.
- Match Solar Output: Use a charge controller or inverter matched to the Cybertruck’s Level 1 input (120V, up to 16A). Even at 400 W (~3.3A), efficiency trends should mirror your 1 kW test, scaled down.
- Daily Cycle: Solar output peaks midday, but so do ambient temps (e.g., 80-100°F), increasing cooling demand. Charging from, say, 6-10 AM captures rising output (50-80% of peak) while dodging heat penalties. Late afternoon (4-6 PM) could supplement, but the battery may already be warm from the day.
- Range Impact: At 300 W effective (400 W solar at 75% efficiency), 6 hours of morning charging adds ~1.8 kWh, or 4-6 miles. Over a week-long trip, that’s 28-42 miles—modest but valuable for remote travel.
- State of Charge (SoC): Efficiency drops at higher SoC (e.g., >80%), so prioritize topping off when the battery’s lower (20-50%). Your tests didn’t specify SoC, but it’s a factor.
- Solar Variability: Clouds or panel angle reduce output, so early charging also hedges against afternoon weather shifts.
- Heat Pump Quirks: The Cybertruck’s system might activate preemptively if it anticipates heat buildup, even at low rates. Your 40% efficiency drop suggests sensitivity to temp thresholds—worth testing with solar-scale power.
