Jedi2155
- Apr 13, 2020
- Southern California
- 2024 Model Y AWD | FS Cybertruck AWD + FUSC
- Engineer
I believe the switching power supplies vehicles like the Volt was fairly efficient, as it was around that time there was a lot of new research in designing new efficient power supplies (especially in the solar world with 95%+ DC-DC conversion efficiences). A lot of the aspects of efficiency for a power supply comes from cost trade offs, and power electronic costs was a significant concern in the 1st generation Volt (I had a chance to question one of the Volt engineers on this specific topic). My own measurements was 13.5 kWh/charge @ 120v and 12.6 kWh @ 240. With those numbers I was able to determine the base load of the vehicle was around 200watts (with the computers/pumps running), and the net charging efficiency (AC-DC) was slightly highly on 120v (89.6%) vs 240 at (88%) assuming the battery was 10.5 kWh DC per charge implying they probably optimized for 120v charging. BTW the AC meters were calibrated with NIST traceable equipment.That's not quite true, re older Volt, Leaf, RAV4.
They had the older, 80% efficient, cheap chargers so they're always stuck there. It's not the overhead that makes it inefficient, it's just older (cheaper) methods of rectifying AC to the appropriate voltage for charging.
It's just like you can choose a more or less efficient power supply for a PC or your USB powered devices. And when I mean just like, it's basically the same electronics! Power supplies have to adjust for the load they're powering: Chargers, on the other hand, adjust the voltage for the charge level so the load remains as consistent as possible. It's the same thing, just a different control.
So for instance, the chargers for the Gen 2 Zero I have is always that 80% efficient - even if you have the Level 2 6kW one.
