Leesburg, VA
2020 Y Performance & 2022 Y Performance
Today I installed a set of four wheels and tires from Tsportline, and this post summarizes an efficiency comparison I just performed vs. the stock wheels and tires.
What I Bought
  • Tsportline 20" Fully Forged Lightweight Wheels (31.8 pounds)
  • BF Goodrich KO3 Tires (285/65/R20) [note: stock tires are 285/60/R20]
https://tsportline.com/collections/...tweight-tesla-wheel-and-tire-package-set-of-4
The Efficiency Test I Performed
  • I drove 36 highway miles from Leesburg, VA to Blumont, VA and back at approximately 65 mph.
  • I first did this route with the stock wheels and tires that came with my Cyberbeast and no aero covers, and then I repeated it with the new wheels/tires.
The Results
  • The new wheels/tires (415 wh/mi) are less efficient by 11% relative to the wheels/tires that come with the Cybertruck (375 wh/mi).
Tesla Cybertruck 20" Tsportline Lightweight Wheels + KO2 Tires Less Efficient by 11% (vs. Stock) Screenshot 2024-09-19 at 2.41.11 PM
Tesla Cybertruck 20" Tsportline Lightweight Wheels + KO2 Tires Less Efficient by 11% (vs. Stock) IMG_0037
Tesla Cybertruck 20" Tsportline Lightweight Wheels + KO2 Tires Less Efficient by 11% (vs. Stock) IMG_0059
Tesla Cybertruck 20" Tsportline Lightweight Wheels + KO2 Tires Less Efficient by 11% (vs. Stock) 1000003196-
Cyberus
What I Bought
The Results
Swapped for a true AT Tire 1500 miles ago, and my avg increase is only around 20 wh/mi. Give it some time.
NorthernVirginiaCT
Leesburg, VA
I wonder how much is the tire and how much is the wheel.
It's, $5,995 right now for the wheel/tire package after the current $500 off promotion, and the wheels themselves are $3,695 after the same promotion.
Therefore, the wheel portion of the cost is $3,695, and the tire portion is $2,300.
RoboTaxi
Kansas
Beast when the gods bless me
I might have went with the white letters facing out ?
Speedr
Dual Motor Cybertruck
What I Bought
The Results
Thanks for doing this! It's in line with what I expected, and is not bad considering.
BTW, can you include a full side view of your truck with its new shoes?
Gundo
Gundo
Connecticut
Porsche C2S
What is wheel circumference of each?
Looks like BFG TA is smaller by a decent margin.
Without adjusting for this, couldn't efficiency numbers be off?
Ri22
George
Land of Entrapment
M3 CT
Cinematographer
What I Bought
The Results
No mention of air pressures.
NorthernVirginiaCT
Leesburg, VA
The stock tires from Tesla are 285/60/R20 vs 285/65/R20 for the ones installed.
Therefore, the with lf the tires is the same, bur the new ones have a bigger sidewall.
Also, the stock tires are load range D, whereas the new ones can handle more weight as load range E.
https://www.tesla.com/ownersmanual/cybertruck/en_us/GUID-9284C9F2-A2F2-4604-83BF-6599F47766B7.html
rb92gt
Ryan
New ones are taller, requires more energy to roll.
Gundo
Gundo
Connecticut
Porsche C2S
Sometimes even same tire size (285/65 in this case) can have a different diameter. IN this case it seems to be about an inch. But I'm not sure how much af an impact on efficiency this could have.
BFGoodrich All Terrain T/A KO3
Inflated Diameter: 34.6
Revs Per Mile: 602
VS.
Goodyear Wrangler Territory RT
Factory OEM Size: 285/65R20
Overall Diameter: 33.5"
Revs Per Mile: 622. 20
(Design: Light Truck / LT)
