CyberTruckyWucky
T
2026 long range cybertruck
Tesla Cybertruck CYBERTRUCK RWD — (FSD) REAL-WORLD INTERSTATE ENERGY CONSUMPTION OBSERVATION ~4,700-Mile Test 19839
INSTALLER INFORMATION
High Tech Motorsports & Fabrication
(470) 545-0859
https://maps.app.goo.gl/ry7ZPtXWR4mY4mXt9
SUMMARY
No Tonneau Cover
• 2,347 mi
423.9 Wh/mi
Manual Tonneau Installed
• 2,347 mi
382.2 Wh/mi
Observed Reduction in Energy Consumption
~9.84%
~4,700-Mile Long-Haul Operational Evaluation (100% FSD)
2026 Cybertruck RWD | California ⇄ Georgia | I-40 Corridor
Recently completed an approximately 4,700-mile interstate trip in a 2026 Cybertruck RWD and observed a measurable reduction in highway-speed energy consumption after installing a manual tonneau cover for the return leg.
This was not a laboratory-controlled aerodynamic study.
This was normal owner-operated interstate driving under practical long-haul conditions.
Full observational report in the following link:
VEHICLE CONFIGURATION
• 2026 Cybertruck RWD
• Goodyear Territory HT tires
• Tire size: 285/70R18 116H
• OEM wheels with factory aero covers installed
• Stock ride height maintained
• No aerodynamic body modifications
• Only external accessory: UP performance light bar
• Vehicle load: ~200 lb occupant + ~20 lb food/water
• No heavy cargo load carried
INTERSTATE COMPARISON
Trip A
— Outbound Baseline
• Distance: 2,347 mi
• Configuration: No tonneau cover
• Average consumption: 423.9 Wh/mi
Trip B — Return Comparison
• Configuration: Manual tonneau cover installed
• Average consumption: 382.2 Wh/mi
Observed Reduction in Energy Consumption:
~9.84%
Calculation:
(423.9 − 382.2) ÷ 423.9 = 9.84%
PROJECTED ENERGY SAVINGS
Per 1,000 miles: ~41.7 kWh saved
Per 5,000 miles: ~208.5 kWh saved
Per 10,000 miles: ~417 kWh saved
Per 15,000 miles: ~625.5 kWh saved
Per 20,000 miles: ~834 kWh saved
Estimated annual electricity savings:
At $0.15/kWh: 10,000 mi/year = ~$63 saved
15,000 mi/year = ~$94 saved
20,000 mi/year = ~$125 saved
At $0.25/kWh: 10,000 mi/year = ~$104 saved
15,000 mi/year = ~$156 saved
20,000 mi/year = ~$209 saved
At $0.40/kWh: 10,000 mi/year = ~$167 saved
15,000 mi/year = ~$250 saved
20,000 mi/year = ~$334 saved
OPERATING CONDITIONS
Both interstate legs included:
• Sustained ~70–75 mph highway cruising
• Rain exposure
• Crosswinds
• HVAC operation
• Night driving
• Interstate charging cycles
• Mixed traffic density
• Elevation variation
• Extended-duration operation
Testing conditions were not laboratory-controlled and better represent practical owner usage.
KEY OBSERVATIONS
Interstate Stability
The lower return-leg Wh/mi trend remained comparatively stable across thousands of interstate miles rather than appearing only during isolated segments.
Potential Aerodynamic Influence
Observed results may suggest reduced rear-bed turbulence during sustained highway-speed operation when the tonneau cover is installed.
At interstate speeds, aerodynamic drag becomes increasingly dominant relative to lower-speed urban driving.
Long-Haul Operational Impact
Over multi-thousand-mile travel distances, even moderate reductions in Wh/mi compound into meaningful operational differences including:
• Reduced charging frequency
• Lower total trip energy demand
• Increased route flexibility
• Reduced charging dwell dependency
Dataset Characteristics
Most public tonneau efficiency discussions currently rely on:
• Short-duration testing
• Estimated projections
• Low-mileage comparisons
• Modified vehicle setups
This observation instead came from:
• ~4,700 interstate miles
• The same vehicle
• The same driver
• Similar route profiles
• Similar cruise-speed ranges
• Stock wheel/tire configuration maintained throughout testing
PRELIMINARY CONCLUSION
Observed real-world interstate data suggests the manual tonneau cover configuration may provide measurable reductions in highway-speed energy consumption on the Cybertruck RWD platform during sustained long-haul operation.
The observed ~9.84% reduction in average energy consumption across approximately 2,347 interstate miles appears sufficiently large to warrant additional controlled testing and broader owner dataset comparison.
LONG TERM FOLLOW UP
Additional efficiency and operational updates will be recorded every ~3 months under normal daily driving conditions to evaluate long-term stability of the observed interstate efficiency gains.
3 MONTH WAYPOINT
6 MONTH WAYPOINT
9 MONTH WAYPOINT
Tesla Cybertruck CYBERTRUCK RWD — (FSD) REAL-WORLD INTERSTATE ENERGY CONSUMPTION OBSERVATION ~4,700-Mile Test 119926-6314b386b62756f25efcfcebb68d7c0a
Tesla Cybertruck CYBERTRUCK RWD — (FSD) REAL-WORLD INTERSTATE ENERGY CONSUMPTION OBSERVATION ~4,700-Mile Test 119925-dfc7e3871ed00d6c3f326a5aad0638d4
Tesla Cybertruck CYBERTRUCK RWD — (FSD) REAL-WORLD INTERSTATE ENERGY CONSUMPTION OBSERVATION ~4,700-Mile Test 119923-dc234793e42ecbb87670c1d00c0d1e10
CyberTruckyWucky
CyberTruckyWucky
T
UPDATE
Still collecting return-trip data.
The manual tonneau + real-world interstate driving is producing surprisingly consistent efficiency gains over the return run.
Current observations:
  1. Significant highway efficiency improvement
  2. Night driving efficiency notably better
  3. Stable cruising speed matters heavily
  4. Human fatigue became the limiting factor before range
Will post full outbound vs return dataset once the trip is complete.
CyberWalrus
FL
CYBERTRUCK
That is really nice cover you added!! I hope can make more for the rest of the RWD drive community.
The efficiency improvement is impressive!
When I had my RWD, I drove from FL to NY twice ~2k miles round trip each. 1st trip was Thanksgiving time, got ~380Wh/mi, then Christmas trip ~425Wh/mi. I think colder weather took a hit.
If I had your cover, I think it would be close to 350Wh/mi on warm weather.
The RWD efficiency is excellent, I remember driving around town and can get down to 220Wh/mi.
Tesla Cybertruck CYBERTRUCK RWD — (FSD) REAL-WORLD INTERSTATE ENERGY CONSUMPTION OBSERVATION ~4,700-Mile Test {filename}
(470) 545-0859
SUMMARY
No Tonneau Cover
• 2,347 mi
423.9 Wh/mi
• 2,347 mi
382.2 Wh/mi
~9.84%
Trip A
— Outbound Baseline
~9.84%
Calculation:
• Rain exposure
• Crosswinds
• HVAC operation
• Night driving
KEY OBSERVATIONS
• The same vehicle
• The same driver
Thanks for the trip report. Sounds like a good one!
I noticed you said the outbound trip was "primarily 70-75 mph" and the return trip was simply "sustained freeway speeds". Small changes in cruising speed will have a relatively large impact on efficiency. So, regardless of the many miles logged, I think a short test (30-50 miles for each configuration) that better controlled for wind, speed and temperature would provide more reliable results.
My $0.02
comet2
Geo
Muskogee, OK
26 Model Y AWD & 26 DM AWD (10-Day Legend)
174 units sold i think
Ahh... the 173/ 174 confusion. This was the first one I created. I specifically prompted for the removal of 174. Facepalm!!!
Tesla Cybertruck CYBERTRUCK RWD — (FSD) REAL-WORLD INTERSTATE ENERGY CONSUMPTION OBSERVATION ~4,700-Mile Test 1779822669071-cr
