Trbizwiz
- Tom
- Apr 7, 2023
- Bradenton FL
- Model X Plaid, Model Y Performance, Model 3 RWD, Dodge Challenger
- Occupation
- Logistics
I thought the factory tires were 275, thanks for the catch!You added 6.35mm of width to each side of the wheel(added 1/2" width) then pulled out the wheel 13.5mm outward from stock configuration.
Your inner wheel lip sits outward 7.15 mm more than a factory stock wheel and 19.85mm outward on your outer wheel lip.
You will be a little over 1 inch taller as stated in your tire specs not 2
Thanks also for the extra math, it sounds like I should clear everything with no problems, and at worst stick out 3/4 of an inch over factory.
