Aptera shows how mega-body-piece construction works in their pre-production...
DPye_BC
Durwin
BC, Canada
Foundation Series Cyberbeast (Nov. 2024)
Teacher
The aerodynamics of the Aptera are specifically designed for reducing drag while in ground effect. It has very little in common with aircraft body designs. The shape doesn't create any lift - it actually provides some downforce to keep it on the road. Chris Anthony says it bears more resemblance to sharks and dolphins swimming close to the sea floor.
Aircraft bodies rarely give much if any lift either.
It is built the same as a small aircraft. It is designed to reduce drag… much like a small aircraft. They are made of composites very similar to a small aircraft. Last I checked, dolphins are made of meat.
They are much closer to an aircraft than pretty much any other known object.
Tho you could build it to have body lift, most planes don't. That's for the wings and aero surfaces that you control tightly for performance.
...That is what I went to school for. o-o
