Bed outlets how to keep on?
Ken in Miami
Ken
Miami, Fl.
2024 Foundation series
Real Estate/ Agriculture
I’m putting a 59 quart fridge/ freezer in the vault along with a chest freezer that I want power on all the time without having to reset in 12 hours. The dash outlet menu shows a 12 hour time limit. Is there a way to have power to bed outlets all the time?
Ken in Miami
Ken
Miami, Fl.
https://www.tesla.com/ownersmanual/cybertruck/en_us/GUID-DA020526-B42E-4C0E-AE1E-BB22072D48B6.html
See keep outlets on. Seems to be 12hr/5%.
PowerShare works longer tho so odd.
I just installed the cooler and two things I noticed, first when the cooler is on there is a whine that comes from the front of the vehicle when vehicle is off. I’m thinking it may be an inverter whine?
My cooler and freezer will be of no value to me if I have to reset the 12 hour timer!
Lasttoy
Paul
St Augustine, FL
Shuts off if charging. All accessories go dead.
That is ridiculous.
mstatkus
WA
Cybertruck, Model Y, Model 3
DevOps
I don't see a Siri Shortcut for the Keep Outlets On feature to automate resetting it either. You'd have to set a reminder and manually toggle it via app in the mean time.
Other possible option would be get the 120V adapter off the mobile charger, but I'd read up on that to make sure that stays powered like PowerShare. https://shop.tesla.com/product/powershare-outlet-adapter (possible work around)
But like stated here if you charge the truck the outlets don't work either.
My old camp/backup setup was a ECOFlow Delta 2 w/ smart battery. But even with X-Boost running 2 freezers off it was playing a game of chicken with the compressors kicking on at the exact same time tripping the unit. Those would last for around ~16hrs but back feeding with solar or one of the 48V Accessory feeds could keep that setup running. I sometimes use these as a buffer still but they've mostly become redundant.
My big chest freezer was 88w, and my upright was 150w but peak load on startup definitely exceeded the 2400w limit of X-Boost so I staggered them and generally got away with it in a power outage. Can also control them or get alerts via ECOFlow app via wifi/bluetooth.
CyberT
Orange County, CA
Service Technician
eswimm
Charlotte, NC
Model Y, Cybertruck
That is ridiculous.
Not just if charging, the power outlets can't be enabled if the CT is plugged in to a level 1 or 2 charger even if charging is complete. To make this work, it would likely need an inverter and battery backup to provide power while charging (or a swap to shore power). It might be possible to programmatically enable the outlets every 12hr via API, or potentially use camping mode (some people have claimed the outlets stay on indefinitely in camping mode). There would likely be a significant vampire drain associated with either solution, in addition to power requirements of the 2 fridge/freezers.
Ken in Miami
Ken
Miami, Fl.
I thought this would be easy! Haha fool me!
The truck is always plugged in when not used( set to charge at night) so what I gather is just having the truck plugged in will turn off the outlets? Ok
What if purchased one of the small battery back ups, leave it always plugged into the bed outlet and run the fridge/freezer and freezer off of the battery back up always? Would the back up have enough power to run them over night and would it charge when driving the car? This is getting heavy weight wise and confusing.
eswimm
Charlotte, NC
Model Y, Cybertruck
That was my thought as well, you can certainly power a UPS from the bed outlets. The biggest issue is going to be getting one big enough to handle the load when the compressors turn on and last long enough. Another option would be a rigging up a small transfer switch, power from the outlets while unplugged and switch over to an extension cord from the house while plugged in. As long as all your AC charging is done at home, it would be less weight and cost.
CyberT
Orange County, CA
Service Technician
That's what I posted above lol.
Step 1: find out how much power your fridge/frezzer uses.
Step 2: Multiply the power times how long you need it to last before the bed outlets are turned back on to recharge the battery.
Step 3: Go to EcoFlow.com and go shopping.
I have a couple of their units. Three features stand out: LFP battery with a 10-year warranty. You can connect to the battery via an App with Wi-Fi or Bluetooth, and their lightning-fast switchover UPS and EPS
Ken in Miami
Ken
Miami, Fl.
plugged in. As long as charging is done at home, it would be less weight and cost.
Well, my wife just tried to drive it with fridge plugged in to the bed outlet and a message came on the screen
Close bet outlet cover. She sta
Guys, thanks for the help!
I am not familiar with battery backup units and know the freezer rating is .75 kw in 24 hours use and the fridge/freezer unit states it is a 65 watt unit on rapid cooling. It should be as simple as plugging it in but no chance! Now my wife calls and says she was going to use the truck but a screen message comes up stating the electrical outlet door is open and it wont allow her to navigate. I’m hoping she just misinterpreted and the screen warning would not stop her from navigating since there is no way to use the outlet while driving with the outlet door closed.
im going to research the power stations now.
eswimm
Charlotte, NC
Model Y, Cybertruck
It's just a warning that the cover is open, it can be dismissed without issue.
