Vulnerable PCS versions are going to fail through normal use. Using the outlet is no worse than Powershare.Has anyone heard of the PCS failing by using the 14-50 outlet? I'd like to use my truckbed 14-50 outlet for backup power to house.
My PCS is still working. It's version E. I haven't used it yet to power the house. Just wondering if people using it that way were getting failures. Unfortunately the nearest supercharger is 1.5 hrs away.In my unprofessional opinion. Anything that uses the power conversion system that can help cause the PCS to fail. Has yours not been replaced? We just were charging ours at home and it failed completely. Could no longer charge at home. Could supercharge because that doesn’t go through the PCS.
