- May 27, 2024
- SE Michigan
- Cyberbeast
The installation instructions have a torque spec for the front nut, not a gap. It might be possible to give it a few more turns to line things up better (but I'd try pushing gently on the trim first to make sure it can move and there isn't something else interfering or the part to too thick)Hi fellow CT owners,
Not sure if I am the first customer to receive the newest cantrail trim replacement after the recall!!
Here is the story, my driver side cantrail trim piece was adjusted in April 2024, 1 month after I took delivery last year (yep, early adopter here). After that, the cantrail trim piece looks great on both sides, nice and evenly mounted. But I noticed a squeaking noise emanating from the driver side windshield to a point became very noticeable at every slight bump on paved road. Took my truck in for another service in July 2024, Tesla readjusted the driver side cantrail trim piece, the squeaking noise stopped, but a noticeable gap was formed between the driver side cantrail trim piece and the original joined spot. That gap had been growing, and the misalignment got worse, and I saw the weather strip has pulled back exposing the bolts.
Fast forward to 3/8/25, took my CT in for the Cybertent installation and to also address the cantrail issue, while the truck was in the service center, the nationwide recall news came out in Mid-March, the service center called me 2 days later stated that they had ordered the wrong part, and I waited 10 days for the "correct" cantrail trim to arrived. I finally picked up my truck yesterday after the serviceappointment, the cantrail trim does NOT look good at all, the gap got tiny bit smaller, but still looks very uneven and misaligned. Plus, a circular burned mark appeared on the base of the new trim piece (welding mark), I also found a patch of scratches on this brand new trim.
Please see below pictures, and judge yourself. Cosmetically, it looks horrible! However, I must say, the team at the service center was very nice, courteous and super communicative.
Questions to all of you: what would you do? Would you accept this "recall repair"?
Discoloration is due to the stud being welded to the stainless now. Might buff out along with the scratches.
