Charging Cybertruck & RV at same time - future update?
bftx
TX
I heard the a future update would allow a Cybertruck to be charging while concurrently powering an RV.
Any news or updates on this?
mitch9
Mitch
Boston, MA
2025 Dual Motor Cybertruck
Can be "SuperCharging", that is DC charging. AC charging uses the same circuitry as powering the AC outlets, so no, unless they add another converter, and that is not likely, because, as Elon has said many times, "the best part is, no part" :)
Fugue
Kentucky
Cybertruck AWD FSD, Model Y LR FSD
Tech Industry Grunt
In what context?
If you want the RV powered while you're at a Supercharger, just have enough RV battery to get you through the charging session.
If you mean at a campsite, plug the RV into shore power. Plug a mobile charger into an outlet on the RV. Charge your truck with it.
SabrToothSqrl
PA
CT Ordered | 2023 Y, X, Previous: 2013 S85, 2018 3, 2019X. 3 Wranglers, 2 Tahoes
Cat Herder
If you plug the RV into the truck and the truck into the RV.... something something UNLIMITED POWER HACK!
That was Wes theorizing that since the PCS has two DCAC modules it could potentially charge while supplying partial power to the outlets. Depends how the ACJB works though and I haven't seen a tear down of that module.
In the interim, I have a 14-50 splitter to allow powering trailer and truck from one pedestal. Along with a Power Watchdog to monitor current draw on each phase.
Next level would be dual Victron Multiplus II 48V/5000 units and a 15kWh pack in the trailer. Then add a 14-50 outlet for truck charging (UWC if I'm really fancy). Plus 14-50 plug pigtail to quickly recharge trailer from truck, when needed. This avoids the high idle loss of running the truck outlets.
SabrToothSqrl
PA
Cat Herder
Financing just changed.
If I can't get 3.99%, I will not be buying.
Feeling like a bait and switch here.
Tesla Cybertruck Charging Cybertruck & RV at same time - future update? 1776282883789-71
