rudedawg78
- Ernie
- Jun 8, 2020
- South Carolina
- 2024 AWD Cybertruck (Foundation Series) "Wraith"
- Occupation
- Retired USAF, Emergency Manager
69!
And of course that makes it realas the OP on Reddit answered, he checked behind the wheels and spotted a motor behind both axels. That's why it should be dual motor
Aren’t there 4 axles on a Cybertruck?as the OP on Reddit answered, he checked behind the wheels and spotted a motor behind both axels. That's why it should be dual motor
No.Aren’t there 4 axles on a Cybertruck?
If the toll people choose to refer to it as a 2-axle vehicle is not important to me. What is important to me is whether or not the shaft going to a wheel is sharing a motor with another wheel. On the CT I see an axle (or a shaft and CV joints) going to each wheel. Whether that shaft is driven by its own motor or to a shared motor is the question. I am assuming that in a tri-motor trim there will be 2 axle/shafts going to one gearbox and one motor, at one end, and two axle/shafts going to 2 gearboxes and 2 motors at the other end. You clearly have another way of looking at it and that is fine.
So many people are going to start getting scratches on the stainless and crying online about it.Went through crash and this was all the damage? (Photo taken from the Reddit thread)
And for 95% of people they will look at the drive assembly and not be able to correctly label any of the parts- see first image. The main visual difference for the dual motor axle seems to be the symmetry as seen in the second image vs the single motor axle- 3rd image. There is a post on here with a person saying they can tell that one of the crash test models was a single motor, but there is no way you can tell with how covered up the undercarriage and wheel wells are.I find it's easier to call them what they are: "driveshafts".
That's what you call them on independent suspension setups like the Teslas have, and CT.
There are no "axles" on a non-driven independent suspension, but as Cybergus pointed out, some people call a whole independent suspension assembly an "axle".
An axle can be driven and not driven, whereas a driveshaft is only driven. It's in the name.
The other variation to bring in here is if CT has longitudinally mounted dual motor assemblies on each end instead of transverse mounted motors. That would be good for larger suspension setups like the CT, as it will give them more room for longer wishbones, which in turn gives them more travel, and more height adjustable range. (it's all about keeping the CV joint angle low)
If so even someone familiar with the already available motor assemblies could easily mistake a dual motor setup as a single motor, because they are only looking at one side of the assembly, say behind the axle line, whilst there is another motor hidden in front of it.
What does a quad-motor wheel look like :^)I'm guessing the covered hubcaps are tri-motor and the smaller wheels are the dual motor.
Each or your photos show only one motor each. The top is the rear cradle of what could be the early single motor Model S. No way to tell if the front end had another motor or not. What some may see as a second motor, is the inverter for that motor (left side of the photo, right side of the vehicle).Pop quiz: how many motors in this Tesla drivetrain?
What about this one?
...or this one?
I think it's fairly obvious from the photos, but a casual inspection of a covered underside may not be determinative.
If the front wheels have driveshafts then there's obviously at least 2 motors, but it may be difficult to tell if an axle has 1 motor or two.
