CT charging with a generator
dbrockman2
Louisville, KY
2024 Cybertruck AWD
Pilot
I have a trip coming up where we will be camping with an RV for about 10 days in late July. We will be boondocking with a generator. There aren't any superchargers near by not that I want to spend part of my day plugged in to a SC. Has anyone used the neutral bonding plugs from Amazon? They are mentioned on some of the YT videos as being necessary to use a generator to charge. Plan to use the 30A plug on the generator to put a few electrons in the battery each day when we don't need the RV running. This will be a once a year event so its not like this will happen frequently.
TIA!
TIA!
Your generator may already have neutral and ground bonded. Do you have a meter to check with?
Otherwise, yeah they will need connected somewhere.
Note that a travel trailer 30A plug is 120V and the generator is 240V. You can get both types of adapter for the Mobile Connector.
dbrockman2
dbrockman2
Louisville, KY
2024 Cybertruck AWD
Pilot
I do have a multi-meter, how can I check it?
30A output on the generator likely has NG bond. Check the scematics of your generator or you can post it here.
Also having gone camping with the CT I would suggest you TEST the generator setup at home BEFORE you go out beyond the reach of a supercharger, better to figure out the surprise win in your driveway than 70 miles out in the back country.
CYBERRIG
Rick
Richmond, TX
24 CT, 22 MY
I’ve used a generator on mine before. Get a surge protector like you would use on an RV just to be safe. It won’t let power through at all if it’s reversed or not a good flow.
Lasttoy
Paul
St Augustine, FL
My Honda 3000 works just fine. I get 4 miles per hour charge. Take a can of gas. ?
mcm4ss
Matt
Cybertruck and 7 others
Landscaper
I have a 9kw Firman. charges 240. takes about 4 hrs from 30% to 80%. We start dinner, power the rv, have a few then shut down. Truck fully charged. I do this two days before I go through 5 gallons of fuel.
carsonag01
Carson
San Antonio, TX
carsonw.com
Cybertruck FS AWD, 2020 M3, 2024 M3
Digital Marketer
30% to 80% would be 61.5 kWh. If this took 4 hours, you're adding ~15 kW every hour. Is that right?
furbyland
Lexington, KY
2023 Model S LR, 2024 CT AWD
I.T.
At 240V, wouldn't that be roughly 62.5A? Hardly possible with said generator...
VAF84
Central Texas
2024 Sierra EV Denali, EX - 23 Lightning Lariat Extended Range 10mo./21k mi
I used the following items when I was charging off diesel generators. Not sure if it helps.
Power adapter
Extension
speedstuff
El Dorado Hills
26 CT Beast, 24 FS CT Beast, 25 MSP, 23 C8 Z06, 22 GMC 2500HD
ecom
I have used this generator (needed the amazon bonding plug) and it charges @ 7KWH with the mobile connector charger on the 240v port.
FIRMAN T07571F 9400/7500W Tri Fuel Electric Start Portable Generator 50A
Cybergirl
Illinois and Arizona
TIA!
Sure they work, but you can make a bonding plug from an old three prong extension cord plug. Cut off the plug a couple of inches back, strip the insulation from the wires, then connect the white (neutral) wire to the green (ground) wire and cover the black (hot) wire. You then plug it into one of the 120Vac outlets on the generator.
