- Gus
- May 22, 2021
- Austin, TX
- 1981 DeLorean, 2024 Cybertruck
- Occupation
- IT Specialist
Clearly.I am just stating what I see.
I looked back through the thread and i think i meant to say i don't think you are wrong. I completely agree with their statement about the body panels. Sorry for ruffling feathers here. I think its very likely that they reduced the thickness of panels due to the substantial interior body components. i have been saying for a very long time that i think the exoskeleton will play much less a role in the strength than many of the origami believers would have suggested. Really, if we step back, aside from the dramatically innovative castings and structural pack, the rest of the frame is similar to their other vehicles except that the finish exterior body panels are stainless. I am sure they do play probably a larger part in the strength of the body that say the model Y, but the recent images do prove that there is a very substantial interior body, which was highly debated for years.You seem defensive for some reason. I am just stating what I see.
I do not think the production model will be a mix of panel thickness. It is not reasonable. The structural, load bearing skin will be a significant part of the overall integrity of the vehicle. Having a rigid and stable outer skin and a support structure under that will be how all of this is achieved.I think you are wrong. Clearly now with the recent photos there is a very substantial inner steel body and the rear castings are clearly supporting much of the load near the sail pillars. Tesla is very obviously making decisions to try to reduce the weight of the truck. They reduced the dimensions by 5%, removed the metal bed and solid surface dash. I bet they are struggling to get to that holy grail of 500 mi range so they are also reducing the panel thickness everywhere except at the doors to maintain the bullet resistant claim
Also, it would make the truck age weirdly if there was alot of panel thickness variation. There will be some... leading and trailing edges, for instance... that will have transverse strengthening so the skin folds inward instead of peels outwards in crashes.I do not think the production model will be a mix of panel thickness. It is not reasonable. The structural, load bearing skin will be a significant part of the overall integrity of the vehicle. Having a rigid and stable outer skin and a support structure under that will be how all of this is achieved.
The proto type does not need to be as strong and is more of a concept delvery. Having the fully developed engineering is not how the process works. Developing the final form takes lots of trial and error.
I do not like unsupported conjecture parading as 'clearly apparent' statements.You seem defensive for some reason. I am just stating what I see.
Is it not clearly apparent that there is a substantial interior body inside the SS exoskeleton. The new images are really the first confirmation of that. I thought it made it clearly apparent.I do not like unsupported conjecture parading as 'clearly apparent' statements.
The sad part is that we will likely never know about the actual structural loading. Even Munro isn't going to do a structural finite analysis of the structure to determine how much of the load is actually transferred through the exoskeleton. We may get a better idea if they do greatly scale back the thickness of the SS it would give us a very good indication that its not holding much load. It could also be that as they progressed with the casting design they realized that its much more effective to use the casting to transfer the load with less weight than it is to use the skin. With the recent pictures its become very clear that there is substantial interior body/framing.I do not think the production model will be a mix of panel thickness. It is not reasonable. The structural, load bearing skin will be a significant part of the overall integrity of the vehicle. Having a rigid and stable outer skin and a support structure under that will be how all of this is achieved.
A few pieces that can barely stand on their own is absolutely no evidence of an internal frame design, let alone that the skin will be no more than any other unibody car.Is it not clearly apparent that there is a substantial interior body inside the SS exoskeleton. The new images are really the first confirmation of that. I thought it made it clearly apparent.
This is also untrue. What do you think is in the very expensive reports that Munro sells to automotive competitors?Even Munro isn't going to do a structural finite analysis of the structure...
Do you know what structural finite analysis is?A few pieces that can barely stand on their own is absolutely no evidence of an internal frame design, let alone that the skin will be no more than any other unibody car.
Hence, unfounded conjecture parading as certain statements. You don't even know what color the body in white will be coated in for the production models because we haven't seen any from production models.
Here is an example video. For some reason it won’t let me put a link in from my phone. . If Munro did finite element analysts on the complex shapes of anything he pulls apart I would be extremely surprised. I have seen that they will do chemical analysis and measure thicknesses and determine metal properties etc.I do not, but it sounds really techy, huh?
I saw that Sean in person. I don’t think anyone has ever seen the sail pillar storage IRL. So it’s likely that it was only actually created in a rendering of the truck. Seeing how beefy that aluminum casting is and the fact that there are these nice clean circular glue ready attachment points on the castings for the SS panels, I would doubt that sail pillar storage is a thing anymore and they may just bend side and combine that sail pillar and quarter panel. My guess would be that will definitely be lighter than 3 mmbut the prototype has some, like, 1mm or less panels?
not to suggest anything more than that the prototype construction is a probably a poor gauge of anything about the production model
in any event, I’ve long ago seen some structural engineers who specialize in metal suggest that two common effects were likely to be seen in the CT: oil canning was one
the other was (translating from nerd speak I don’t remember specifically) was basically the noises the flat sheets would make under vibration or jostling - similar to the noises one might hear if waiving around a handsaw. Suggestion was that to avoid this Tesla would need to fill the interior voids with a hardening sort of expanding foam adhesive.
BTW, what did you make of the “sail storage” seam on the original prototype?
