- Oct 3, 2020
- Western Washington, USA
A tank does not decrease runtimes, it increases them. Because the tank has to be inflated higher than the tire pressure. And when the tank is empty, it has to be re-pressurized. This is a common error in logic, that the tank helps reduce runtimes. It increases runtimes.Yeah 1 Gallon isn't going to do a lot but it helps keep down on continuous runtime (ARB offers a 4L tank for their twin compressor which does indeed help). But it can be there as an add-on for using it for other items out of the truck, like nail guns, etc. The key for me is not waiting 25 minutes to fill a tire and burning it out. A lot of those tankless air compressors have a 10-15 minute run time before you have to shut it off for a while. I would like to at least get 1 tire off of it without worrying the compressor will crap out. The small tanks seem to have a more runtime. Some tankless ones can have long runtimes, but then you are looking at $600+ (like my ARB Twin Air compressor in my Jeep). Since this is a rare event, I just want something that is reliable and will work without breaking the bank.
For the bead, just need some starter spray and a lighter ;-)
All manufacturers of portable compressors recommend transporting them unpressurized and draining the pressure daily. That's just more volume to pump up if you follow their recommendations.
If you don't believe in following their recommendations, and you hook up the compressor you linked above to a MorrFlate system, and the tank was already pressurized to start, it might reduce runtime by 30 seconds to a minute. And you would still need to re-pressurize the tank (if that's how you are using it) or else the next time you use it it would require longer runtimes to fill the tank first. The tank adds no benefit in this application, it is a net negative in multiple ways.
I believe in rigorous thinking, not fuzzy thinking to justify what one wants to believe.
