- Oct 3, 2020
- Western Washington, USA
Defects in the air suspension on delivery would be rare (of course anything is possible).I recently had a delivery day and everything looked good, until I tested the air suspension. It was on entry mode and I raised it to high. The cybertruck seem to struggle to do it and took awhile.
I told the advisor and he came out and told me it was normal. He left and I tried it again. I timed it and it took 2:50 to raise suspension from entry to high. I again told the advisor and he got a manager who came out and said it was normal.
I then asked them to try it on the demo truck and reluctantly they did. The demo raised to high in about 15 seconds. They then said I should accept delivery and have it repaired. I did not accept and left for day.
My question to the owners is, how long does it typically take for your suspension to raise from entry to high? I've seen conflicting results and not sure the reason.
You said, "everything looked good, until I tested the air suspension.". I'll assume you had checked other things first, like Off-Road mode (you have to turn that on to get to "Extract"). If you had selected "Wade Mode" it would have started pressurizing the battery pack to prevent water intrusion during deep water fording. Although Wade Mode has activated for me without undue wait the couple of times I needed it, I believe the manual states it can take up to 30 minutes. I assume that would be if it were activated when the high pressure system found itself in a low state of charge when Wade Mode was activated and it needed to run the compressor extensively.
If the day was warm, and the suspension had been cycled to enter Off-Road Mode and change suspension heights, the compressor could get hot (even without activating Wade Mode). This could happen on a cold day too, if the compressor were cycled enough. I believe the compressor has to be protected by software via a thermocouple to monitor temperature and shutting down if it's duty cycle/temperature is exceeded to prevent it from destroying itself.
How long it would take to exceed the system capacity for heat would depend upon the state of charge when you started testing systems that relied upon the compressor, how much the systems were cycled, and the starting temperature of the compressor and the air it was pumping.
These variables explain why you have seen conflicting results for how long various operations take. The results are not really conflicting, they reflect the fact that the times are not fixed, they are variable depending upon the starting state of the system in terms of initial pressure and temperatures (how much you have been cycling the system in the previous few minutes). When the Cybertruck was just released I saw people continuously cycling these systems as if they were toys, not tools and they will definitely reach their thermal limit and slow down when using them excessively. That could be why the Service Techs said it was normal.
Remember, the little compressor operates in the range of hundreds of pounds, this is not your typical tire inflator, it's going to get hot if you test the various settings. If it took minutes, not seconds, to go from Easy Entry to Extract, I would assume it was because the pump shut down mid-operation to allow heat to dissipate.
While neither you or I can say whether the truck had a defect or hit it's thermal limits (or simply started at a low pressure), I strongly suspect you missed out on taking delivery of the best truck you have never owned simply because you didn't trust the technicians who told you it was normal.
