Extract mode issue
Cybertruck 1974
Everywhere
Every time I select Extract mode and try to lower the truck or try to put into any other suspension mode it does nothing. Each time to get out of Extract Mode I have to select drive and go faster than 10mph and it then lowers. Kind of an issue and if you've actually driven it in EM the suspension is topped out and very stiff. It's kind of laughable when you are on pavement. Anyone else have this issue?
mbukow
Illinois
2018 Model 3 Dual Motor
I am having this issue right now. I hope as I drive forward it will lower. Thanks for posting :)
ChiTownCT
OG Rivet Crew
Chicago
CYBERTRUCK
I've had the truck 2 months and still haven't been in Extract mode, went to very high though.
MyFirstElectricTesla
SoCal
Benz
Something is wrong I guess, Extract Mode can't go faster than 7.5 MPH on mine and I have to select either Very High (25 MPH Max) or High (no limit).
SCTesla
22 Model S, 24 CT
The max speed in extract mode is 10mph according to the service manual.
oisiaa
2018 Model 3 LR RWD, 2021 Model 3 LR
I put mine in extract mode once just to see and the suspension made a pop as it jacked all the way up. Not worried, doubt it was anything other than just a creak.
Boyne
Boyne City, Michigan
2018 MX, 2022 M3, 2024 CT
Retired Naval Officer
Not sure, but when I had the same problem, I found doors must be shut to lower from extract mode. Hope this is accurate and helps.
MetalBonsai
Washington
Cybertruck FS AWD, 2017 Lexus RX350
Artist
1. Click on the bottom left truck icon
2. Go to Dynamics
3. Select Custom (disables Off-Road Mode)
This should re-enable ride height selection on the main screen.
Jabman
New Jersey
Tesla Model S, Ram 1500
I have a service ticket in for a similar issue. I can put the truck in extract mode and then return it to normal height without issue (which I have done a few dozen times at this point when I’m showing the truck off). Recently started hearing a constant hissing at the drivers side rear suspension. As if there is a leak and the air pump continues to run to maintain the height (which it does). I’ll update after my service visit next week. Hopefully it’s nothing.
