Hansshow V2 to replace V1 (rear view mirror)
That Beast Mode
Phil
New Jersey
Except you don't have a functioning speaker if you used the hansshow harness....
Ken is correct.. it may not be obviously noticeable, but its there. You can scroll back and see an earlier post i did with a video to see how to test it for yourself.
I have been contacting @Hansshow Technology for months about this and they keep giving me the same brush off answer "our super techs are working on it and we'll contact you when there is a fix".
FL370
Anders
San Diego, CA
Tesla MS AWD Cybertruck
High Speed Aluminum Transportation
Hopefully someone from Hansshow reads these forums. Perhaps having people like me hold off on buying their products may incentivize them to fix the problem? I want the mirror after having been mirror less for a couple of years, but not at the cost of losing speakers. Nor do I want to put on fuses and splices.
ShockAuto
Reid
Lebanon New Hampshire
shockautostyling.com
2021 Model S Plaid, Cybertruck AWD Configured
Vehicle Wrapper & Content Creator
Why does no one make a USB C to 5v USB C? so we can just plug it into our usb c port in the truck? I would rather power the camera from there vs tapping into the trucks wiring
That Beast Mode
Phil
New Jersey
I have tagged them multiple times and they ignore it. Hopefully people dont buy it until its fixed.
That Beast Mode
Phil
New Jersey
I used the 11” version 2 and has no issue with speaker!
I have the same one and every one seems to have this issue because they all came with a faulty harness design, Hansshow is aware of it they just aren't doing anything about it. A lot of people just dont know they have the issue because Its not super noticeable that the speaker is dead, but it is. Go into the service test settings, test the speakers and you'll see for yourself.
sycamore22
central valley
ct fs
I had issues with the mirror being frozen and had always able to communicate with them via email. They have sent me new connecting cable, new rear camera and the last bit that solved all issues were the new mirror cpu. It’s working flawlessly now and had survived the ride to AZ 2 weeks ago when it was pretty hot. I don’t use the front camera. I’ll check service menu and report back. What speaker issues are people noticing?
Legend_
2025 AWD Cybertruck, 2023 S Plaid, 2015 Honda Odyssey Elite Touring
Day Trader / Entrepreneur
Everything sounds just fine. How can I verify if all are functioning?
sycamore22
central valley
ct fs
Tesla Cybertruck Hansshow V2 to replace V1 (rear view mirror) IMG_0480
TeslaKen
Ken
Overland Park
www.halocybertruck.com
Currently Occupied
The one listed as 25mm tweeter right in the photo above is the one that won't play sound after installing the Hansshow harness, you can use the service menu to try and send sound to it and nothing will happen. Then try the one on the left and it will work just fine for you. (or should)
YukonJack
Greenville, SC
‘06 Tacoma, '24 CyberBeast
With the right pin extraction tool you could pull one of the unused pins (4, 5, or 12), cut the wire, move it to pin 8, and splice it to pin 8 wire (red & yellow power wire).
For whatever reason Hansshow missed the splice on pin 8 to get the pass through but they did pass through the three unused pins that could be used to fix the harness.
I didn’t like the audio line tap and went a different direction.
ethiaop
Sal
WASHU
It’s a bummer all the YouTubers get all of this stuff free pedal it as “works” yet have no clue what they are doing to their cts. I’m talking about Rednav and all the others. They install every item they get and say it’s 10 out of 10 and then disappear. I knew the 2.5 camera would be the very first mod for my 26 beast but alas it’s broken and likely will always be. As a bonus I overhead the Tesla service advisor telling an owner of a 24 ct they would not service until they removed the mirror and wiring. Has anyone else been told this ?
funnbobby
Bob
2025 Cybertruck AWD
All this Chinese made junk is not UL tested let alone circuit tested to determine faulty wiring.
Yet a lot of people fall for this DTC marketing via influencers on YouTube. What a waste of money and time.
sycamore22
central valley
ct fs
Thank you for this instructions! Yes indeed my right tweener speaker is not working. Though honestly I can’t really tell the different listening to music with my non musical ears :)
