Beetlebug62
Ken
Maine, USA
Sometime in September, I thought whatever software update we got, fixed the overheating issue for me. Of course, it was the same time I got a new iPhone 17 Air, so, I wasn't sure if it was the update or the phone. Either way, I no longer have overheating issues.
TexasRaider
JR
Denton
Cybertruck + MS
Civil
Can you please share how you arrived at this conclusion?
Beetlebug62
Ken
Maine, USA
Well, my phone no longer feels too hot to touch, and it charges, so I came to the conclusion that it works now.
I think Apple fixed the wireless charging over-heating issue when wirelessly charging on non Mag-Safe induction chargers. Small misalignments cause overheating from standard Qi wireless chargers on iPhones and this has been documented by users thousands of times on non-Tesla chargers.
In other words, it's not a Tesla problem, it's an iPhone problem. My Android phone works great (and it's going on 8 years of daily use on the original battery).
I added a silicone liner to the phone tray, and it reduced the phone heating significantly.
I can't say if that's due to the thermal insulation provided by the silicone, or if the extra thickness changed the alignment with the coils 🤷‍♂️
turns2stone
Dallas, TX
2026 Tesla Cybertruck Premium AWD, 2024 Tesla Model S Plaid, 2019 BMW i3S
It's not an iPhone problem, it's a '3rd party hardware problem'.
Any charger that doesn't line up to the iPhone's charging coils is going to cause it to overheat. Doesn't matter if it's in a Tesla, Honda, or some mis-aligned Qi charger on a hotel nightstand.
It sounds like the new iPhones are less sensitive to exact positioning (or else they have moved the charging coils to be more compatible with typical Qi charging stands). From what I'm hearing, they act more like most Android phones now when charging on Qi charge stands. That's a welcome change and about time!
HighTechJoe
Earth
2013 P85+, 2014 P85DL, 2026 CyberBeast
I’m having this issue with my iPhone 17 Pro. So, apparently not fixed. I do have a thin case with magsafe magnets in it.
turns2stone
Dallas, TX
As I referenced above, there is no way the Tesla OEM pad (as designed) will ever work properly for iPhones and probably most Androids. The charging coils simply don't line up.
As such, I've been able to DIY a permanent solution that works 100% and can charge two iPhones at 25w each via MagSafe. Much thanks to @Sandman1962 for the 3D print file + design!
Steps:
  1. Print the STL file, I recommend using PETG-CF
  2. Get two of Apple's 2M 25w MagSafe chargers: MGDM4LL/A Model A3503 <-This is the newest Qi 2.2 version, and fits the file from Sandman
  3. Insert the MagSafes and wrap the front of the module with adhesive suede. I used this Dark Gray via Amazon: https://www.amazon.com/dp/B0F6L97BLJ?th=1
  4. Use a dual 30w 120V USB-C charger, to plug into the center console. You can use lower wattage, but this ensures iPhone 16 and newer will charge at 25w via MagSafe
  5. Use double-sided velcro to attach your newly-wrapped pad to the OEM tray. This way you can remove easily if necessary.
  6. Route the two USB-C cables from the top of the tray, around the passenger side of the center console. I used some strong black tape to secure it in various spots to the center console, then up into the rear of the armrest. If you do it right, the wires will be hidden by the passenger seat. You can use some black wire loom tape to tidy up any exposed surfaces or MagSafe wires coming from the top of the tray.
  7. Done! No more overheating, and the phones charge every time. The top of an iPhone camera bump rests just along the top of the 3D printed tray, and the MagSafe lines up.
  8. Also... the key card still works!
Tesla Cybertruck HARDWARE FIX for hot phone charging issue! New wireless charger has a built-in heatsink IMG_0603
Tesla Cybertruck HARDWARE FIX for hot phone charging issue! New wireless charger has a built-in heatsink IMG_0669
Tesla Cybertruck HARDWARE FIX for hot phone charging issue! New wireless charger has a built-in heatsink IMG_0670
Tesla Cybertruck HARDWARE FIX for hot phone charging issue! New wireless charger has a built-in heatsink IMG_0798
Tesla Cybertruck HARDWARE FIX for hot phone charging issue! New wireless charger has a built-in heatsink IMG_0799
shopaholic
Gee
East Bay
Steps:
Looks like OEM solution! Wish one of the vendors or members make a kit for those of us that don’t have or know how to do the printing.
turns2stone
Dallas, TX
Ya. I know there are some vendors with solutions, and I would have preferred to buy something 'off the shelf', but none of them:
  • Use OEM Apple MagSafe
  • Can deliver a full 25w to each device (you need to use the 120V outlet for such, can't split the truck's USB-C to deliver that much power.
  • Maintain key card functionality
So, DIY was the only choice.
Why do you say that?
I finally replaced my ancient Galaxy S8+ for a Galaxy S26 last week and it charges quickly on Cybertruck's wireless charging pads, just like my 8 year old Samsung S8+ did. No excessive heat, just fast charging. Same with the wireless charging pads in my wife's 2024 Model 3 Performance on both of our Android phones.
turns2stone
Dallas, TX
Because the charging coils in the OEM pad don't line up to the coils in your Samsung. Sure, they are 'close enough' to begin a charging session. But a lot of heat is wasted due to (lack of) proximity.
And if you happen to not get them close enough initially, it just won't charge, at all.
Magnets + a better physical design (for the CT charging pad) to ensure there is no air gap due to the camera bump is the only true solution.
Finally OEMs are paying attention to this situation, and the Rivian R2 (and newest-build R1) is one of the first to properly design a wireless pad charger for modern smart phones.
Notice the 'lip' that allows for the camera bump to not interfere with a close fit for the coils.
https://www.rivianwave.com/news/3865/rivian-debuts-new-magsafe-phone-charger-on-latest-r1-builds
Tesla Cybertruck HARDWARE FIX for hot phone charging issue! New wireless charger has a built-in heatsink magsafe-wireless-charger-2-1774625936
Never had any of our Samsung phones not charge or get hot, we just snug them up to the center ridge. Maybe people having trouble have thick cases?
