How is your bed holding up?
firemike
Kingston Tn
2024 Cybertruck
truck driver
I pick up rubber mudflaps from semi trucks and carry them in the bed to put items on. They loose a lot of them. And you can cut them down to fit your purpose.
BillyGee
Bill
Northern California
Technician
Mine is doing great and I've moved heavy machinery and done multiple dump runs.
It's a truck.
Outdoors
Outdoors
North West Montana
What does the semi driver say about that?
firemike
Kingston Tn
2024 Cybertruck
truck driver
I don’t take them off the semi,… I just pick up the ones they loose. And they loose a lot.(and ratchet straps, and load locks, and cheater bars,…etc.).
zip
David
SF Bay Area
MX, M3P
With my FS AWD after 40K mikes and many loads, it showed wear, but no worse than trucks with sprayed in bed liners. When I got the new Cyberbeast I went ahead and got a mat from Amazon that works great.
off topic but always looking for AWD vs BEAST comparisons. can you feel the front-wheel drive bias in the beast?
EWELON
Rori
Wynnewood,PA
I use a tmat liner for mine and it has worked great.
mkdphx
Phoenix
FS Cybertruck dual motor
I don’t notice any difference, though I have it in FSD 99% of the time. Definitely notice a huge difference when I put it in beast mode, it is awesome, if it had wings it would fly.
Chesapeake Beach, MD
'23 MYLR, FS Cyberbeast 280xx
If they are loose, they might lose them.
Back in the day I had an F-150 that I had Rhino lined the bed and it was great, really durable and looked sharp.
How is the plastic holding up for you? Are you using any sort of mat or other protection? It’s a truck and I’m going to use it as one, but I still want it looking presentable.
I’m looking forward to my SAWD coming hopefully in June or July as I ordered pretty early. I check the damn app multiple times a day just staring at the picture of it. Please send help!
I've loved Rhino Liner in the past but I would NOT have that sprayed in the CT. There's too many access points and panels that may have to come off. I've had lots of trucks. I've mostly used spray-in bedliners from Ford or Rhino Liner. I really don't think it's worth it for the CT. I wouldn't even put down bed mats. When I hauled gravel in my last F series, I just put down a big tarp . Then, I just pulled it out when I didn't need it. (twss)
EWELON
Rori
Wynnewood,PA
I was thinking about buying a T mat as well. What do you use for a bed divider?
no need for a divider if you have a tmat. nothing will move once its held in place with the tmat. also you can configure the tmat to maintain use of the underbed storage.
but if you must have a bed divider you need to get one that has at least 1 cm clearance below it so that the tmat goes under. (save your money for some other mod though)
Different people, different uses. Right? I love my bed divider. I can set it so I can stack right between it and the tailgate and nothing falls over. And, hey, EVERYTHING slides if you Beast Mode that Mutha!
EWELON
Rori
Wynnewood,PA
yep. I have a rolling tool box just inside the tailgate, the tmat wheel chocks (sized for milwaukee and toughbuilt wheels) and one blocker hold it right there no problem.
the husky red boxes similarly stay in place against the cab wall. no movement, and a completely open bed.
kpanda17
on top and inside all of that protection
have the great 3x husky bins, spare tire, jacks and stands in the under vault, molleys on the sides of the bed, with molley and L track adds
love this bed
