- Oct 3, 2020
- Washington State
- 2010 F-150, 2018 Model 3 P, FS DM Cybertruck
I've never been able to find detailed weight specs for each configuration on Ford's Website (and I've looked for them a few times over the last couple of years). It's like they are playing games with the true weight and only listing the most favorable weights.(The detailed spec pages on the Ford website are not visible right now, or I am just not awake enough to find them. I was just looking at them the other day. Strange. So going by recollection without being able to check my numbers).
I don't think that's correct because the new for 2024 trim called "Flash" that Car and Driver recommends since it comes with the extended battery but has a low price of $72,000, is listed at the same 6893 lbs. that they list the Platimum model at on the Car and Driver Website:Lightning starts around 6100 lbs in the bare Pro model and goes up to the 6893 number you mentioned with a fully loaded Platinum trim package.
Mostly its the upgraded larger wheel and tire package that is standard on the Platinum that adds that last bit of weight that pushes it higher than the CT. But same increase on the CyberTruck if you put on heavier wheels.
2024 Ford F-150 Lightning Flash 4WD SuperCrew 5.5' Box Features and Specs (caranddriver.com)
So, either Car and Driver is having trouble getting the weights for the various trims from Ford or the Flash weighs the same as the Platinum. And to compare apples to apples would still reguire adding hundreds of lbs. to the Lightning to equip it with a motorized toneau cover you can walk on, four wheel steering, air suspension, dent resistant body panels, etc.
I do agree that the lower cargo capacity of the Lightning is done to save money on lower rated wheels and lighter tires (and also brakes, suspension components and chassis strengthening). All of these things would make the Lightning even heavier and more inefficient (reduce EPA range) than it already is. The Ford engineers did everything they could to make the Lightning comparable to the Cybertruck by shaving a little bit everywhere. The Cybertruck is a heavier-duty truck which says a lot that it comes in the same curb weight range with so much more equipment on board. That's superior engineering (and trucks are all about engineering). Heavier duty tires cost a lot more, all else being equal.
In otherwords, some of the Cybertrucks efficiency advantage is masked by bigger, heavier, stronger wheels and tires (as well as the other factors mentioned above). This means the efficiency difference between the Lightning and the Cybertruck, on an apples to apples basis, is actually huge, especially where you need it the most, on the highway.
Agreed. Both Tesla and Ford had to draw the line on load and towing limits for cost/efficiency reasons. Don't under-estimate how quickly costs scale up as the tow and haul limits rise. The difference between the Lightning and the Cybertruck capabilities simply highlights the engineering superiority of the Cybertruck.My recollection is that Ford specs the Lightning to stay under the 8500 lb class 2A GVWR, so the payload on the Platinum is spec'd at only 1600 lbs or something. Tesla seems happy to have the CT GVWR go over 8500 lbs and push up into Class 2B so they can claim 2500 payload, even on the heavier optioned Beast. and Foundation models. But Tesla doesn't go all he way to 10,000 lbs, likely because of tire and wheel load limits. Class 2B is usually the domain of 3/4 and 1 ton light trucks with 8 lug wheels and load range E tires.
The advantages of a heavier-duty truck is not necessarily really about how much weight you can actually tow and haul, if you drove the Lightning easy and slowly over bumps, you could overload it the max loading of the Cybertruck, likely without issue. I've had my 2010 F-150 loaded to 3600 lbs, more than double it's official capacity of 1750 lbs. (of course I did not drive it down the freeway at 70 mph either). It's all relative, the Cybertruck could just handle the Lightnings max payload weight with more margin for error in terms of rough roads at a higher speed. And with both trucks unloaded, the Cybertruck will just be that much better at handling what is thrown at it in terms of being more rugged on bad unpaved mountain roads at higher speeds. That's what the higher load limits mean to me, a more rugged chassis, suspension, wheels and better towing dynamics with less chassis flex.
This ruggedness is just one reason why I don't find the Lightning even comparable to the Cybertruck. It's an advantage of superior engineering. Granted, the Cybertrucks engineering is unproven in the real world, without millions of miles, but I'm willing to take my chances on that. Because if it can handle what Tesla engineers have put it through, it can probably handle what I'm going to put it through, even if later versions feature key engineering upgrades.
I can hardly wait to replace my 2010 F-150 XLT 4x4 even though I only drive it about once a month, on average. I could have replaced it with a Lightning a year ago while waiting for the Cybertruck, but it wouldn't have made economic sense, and the Lightning just didn't push enough of my buttons to make me go through the hassle of buying one at a regular fucking auto dealership. It wasn't compelling enough to justify that experience at such a high price.
I don't even like my current F-150 enough to justify spending at least $2K to fix the god-awful sounding stereo that is pretty much unlistenable. It sounds like a bad nightmare where everything is cheap as sin, muffled and out of whack. I suppose they thought a crappy stereo in the XLT was a good incentive to get customers to make the $10K or more leap to higher trims (where the stereo still wouldn't be exceptional). Ford has done this to themselves by trying to cover-up their corporate and manufacturing inefficiencies by cutting costs where it really hurts their customers.
I lost faith in Ford long before Tesla had cars on the road, but the alternatives were not any better, IMO. High prices for out-dated junk. And tricky configuration of trims to get you to spend even more for what was essentially the same junk underneath. Oh, it was mostly reliable (for an ICE vehicle), and it worked without too much fuss (for an ICE vehicle), but it was still under-engineered and out-dated junk. Legacy OEM's make their trucks a little better each decade, but are afraid to ever take anything more than baby steps. In the bigger picture, a Ford and a GM and a Dodge were all about the same, even if I had a slight preference for Ford. Truth be told, I didn't like the styling or engineering of any of them, the Ford was the least offensive. Now consumers have a real choice. And the differences are stark.
