Langestreet
- Richard
- Sep 24, 2024
- SW WA
- Cybertruck, Model Y, Excursion,+++
- Occupation
- Mostly Retired :-)
- Thread starter
- #1
For different types of travel, I have used a trailer, a rooftop tent, the truck bed, the front seat, and the back seat. I thought I’d share my back seat solution for those who might want to travel lean.
I know there are commercially available air mattresses which fills up the back seat and levels it out but also takes up the floor space. I opted not to use them instead I've made my own platform which gives me a comfortable sleeping space and retains the storage and provides additional utility.
Here's how I set up to sleep in the back seat:
Part 1: The Platform
- Foam blocks (4xt5x6)
I use high density foam used to carry a canoe on a truck. You may have some packing foam around that you can use instead of purchasing new material.
Amazon.com: WOOWAVE Kayak Carrier Deluxe Carrier Kit Universal Soft Standard Foam Block for Roof Racks Car-Top Replacement with Tie-Downs, 12 inches : Sports & Outdoors
- 2” PVC Flanges (Qty 4)
12 Packs 2" PVC Flange, Table Screw Caps PVC Pipe Fittings for DIY Rod Holder Projects, Making Storage Shelves, Support Feet - Amazon.com - 2”x15” PVC Pipe (Qty 4)
- 6’ pipe insulation (Qty 2)
- Plywood (53.5x25x1/2”)
I shaped this so that there was extra clearance and lined the edges to minimize rubbing the interior surfaces.
- Notes: If you put four legs on it, you can use it as a low table during the day.
- Lay the board in the back seat with the two forward legs only and you’ll have a nice level surface upon which to sleep.
- This will make the space more private and help you sleep.
- Privacy & Thermal Insulation Window Camping Sunshade Curtains for Cybertruck – TESLAUNCH
- Make a new driver profile i.e. “SLEEP”
In this driver profile, set the position for the drivers seat far forward to give more space in the back seat. - Enable Camp Mode from within the temp control panel.
