Leaky Window Seals
JDin NFLA
Joel
Jacksonville Beach
25 Beast previous 22 MYP
Cold areas try silicone spray on a rag over the entire seal. Helps keep flexible. Have used this on other cars with frameless seals and worked
Maaz
Maaz
Torrance, CA
Model S Plaid, Model X Plaid, Cybertruck, Model Y
Realtor
Good news, I went to Lowe’s and got the 3/8” diameter. I trimmed it to length and stuff it into the seal along (opened the flap and push it in) the front side where the rear passenger side glass is meeting the B pillar.
https://www.lowes.com/pd/M-D-20-ft-...Rod-Polyethylene-Window-Weatherstrip/1085965?
Drove it on the highway and it’s fixed!! Temp is 17 degrees and no more wind noise. They only had grey so black would be best, but it’s hard to see the where it is anyway. I like it to match the black rubber so I ordered this:
https://a.co/d/6Cy3Qun
Did the Amazon foam one worked for you? It is a bit too thick and pushes the seal above my window glass.
My Lowe’s one is not staying put after the door
Opens and when it closes causes my rubber seal to stick out of the glass when closed.
adesai414
Wisconsin
I took mine into the SC to get fixed a couple months ago and it worked well for the first few weeks. Now that it is below zero here in the midwest the issue returned. I took some suggestions from this thread and decided to come up with my own fix.
The SC used pieces of foam insulation backing and stuffed it into the seal. It seems like this stuff doesn’t retain its shape in extremely cold temperatures. I followed the instructions from this page and removed the Seal for the Quarter Glass. Then I took out the foam backing that was put in there by the SC and replaced it with a 3/8” Rubber Backer Rod. So far this is holding its shape very well in the cold weather and I am no longer hearing any wind noise leaking inside the cabin.
The rubber backer rod is difficult to push through on its own so I used an Ethernet fishing line and 3-in-1 silicone inside the seal to help pull it through.
Tesla Cybertruck Leaky Window Seals IMG_1098
Tesla Cybertruck Leaky Window Seals IMG_1099
Tesla Cybertruck Leaky Window Seals IMG_1095
Tesla Cybertruck Leaky Window Seals IMG_1103
CyberSav
Cybertruck AWD, Mercedes AMG EQE SUV
Pretty disappointing to have to do this on Cybertruck. I've taken mine in a bunch of times for wind noise issues that get amplified in the cold. On a long winter roadtrip a few weeks back, it was so bad from the passenger side front and back windows that we were stuffing napkins in between the glass and the rubber to get it to stop.
Pretty unacceptable, unpleasant, etc. Shouldn't be happening. I'm glad Tesla is buying back my CT. I can't live with wind noise in my vehicle any longer.
JDin NFLA
Joel
Jacksonville Beach
Try spraying silicon on the seals. Helps keep them soft and flexible.
funnbobby
Bob
2025 Cybertruck AWD
Thanks for attaching the specs for the backer rod. Was truly helpful.
ThaMaddScintist
Ian
CONNECTICUT
BMW 5 series and 4Runner
I noticed this on my Cybertruck as well. A slight (very slight) push on the window down button fixes mine. I haven’t looked into recalibrating the windows and mostly because it only happens in the cold weather. But same thing. High speeds you hear and feel it. Just a small adjustment down and it’s gone. Good luck.
koolio
Greater Boston, MA
Exactly the same with mine. Luckily, it’s only the rear passenger side window.
Also, it seems the majority of people have this issue only with rear passenger window…
Beetlebug62
Ken
Maine, USA
I looked at my rear passenger window today, and opened and closed the door, to watch the window seal from the outside. It appears to go up, hit the top seal, and the window bulges a little when it stops. You can see the tiny gap on the B-pillar edge. To stop it, you'd have to have the window stop just a fraction earlier than its calibrated "top". I'm wondering if I put a little piece of foam, less than ÂĽ" thick, in the top track and recalibrate so that it doesn't go up as far, will the window stay shut against the b-pillar gasket? If I find some foam, I'll do it tomorrow. Should I wash the truck too?
Tesla Cybertruck Leaky Window Seals IMG_2170
AcidSnow
Desperate for a fix, if someone has a good solution please share.
Same issue, rear passenger window. It appears to go up, hit the top seal, and the window bulges a little when it stops leaving a tiny gap for wind noise, slightly lowering the window 1mm allows it to seal properly.
My SC has attempted to fix this exact issue 4 times and have been unsuccessful. They tried stuffing the rubber caulk in the horizontal rubber seal to help push windows in, but the didn't work for long, recalibrating seems to fix for a moment, but somehow it forgets and starts eventually jamming the window to far up again.
kpanda17
escalate and ask for a new door
supa2001
Dallas
Cybertruck AWD, KIA Carnival
Plano Lexington TX SC told me that since it only happens in Winter, just live with it because it'll be too tight for summer. I did the rod fix mentioned here and no issue both winter and summer. DFW SCs suck so much...
Tried to get them to fix an occasional frunk issue, and they ask me if I'd like to "gamble" $230 diagnostic fee if they cannot reproduce the issue.
At least they don't leave the truck in parking lot for days without working on it like Democracy SC did.
