langenbahn
- Doug
- Jun 5, 2024
- Saint Augustine, Florida
- 2020 Model 3RWD, 2021 Model 3AWD
- Occupation
- Finance
- Thread starter
- #1
First, let me start out by saying that I love my AWD Cybertruck. This is my 3rd Tesla and do not believe I will ever own anything but a Tesla. I also thought I knew what I was getting into with respect to towing range. While my experience below was less than ideal, it is certainly doable for the amount of long range towing I do per year. All the above being fact, I could really use some advice.
I live in Saint Augustine, Florida. We migrate down to Marathon, Florida 2 to 3 times per year for lobster season and general fishing. I started the trip with 318 miles of range and was towing a 25 foot center console bay boat. Boat/trailer/fuel weight about 6,300 pounds in total. I was probably hauling another 1,000 pounds of gear (Scuba Tanks, Food, Ice, etc.), myself 180 lbs and my wife 118 lbs. So, in total I believe I was hauling around 7,600 pounds which I know is a lot. Over the 446 mile trip to the keys I averaged 1,140 Wh/mi!!!! We had to stop 5 times and the trip took over 11 hours. The scariest part was before the first leg where the range was dropping so fast that the nav system could not keep up with rerouting us to closer charging stations. It got so bad that it rerouted us to the nearest charging station and then said "stop and charge in order to make it to your destination" - which was the charging station! We got to the exit ramp and basically said I wasn't going to make it. We arrived at the charging station with negative 3% charge. After that, I was extremely conservative and always forced a charge stop around 80 miles to empty. I put the cruise control on 65 MPH for the rest of the trip.
On the way home, I made sure I had other members of the family haul all the gear, I made sure the fuel was pretty much on empty in the boat and also drained the fresh water tank. I averaged 1,051 Wh/mi on the way back which gave me 8.5% better efficiency. All and all, I was only able to go about 80 miles before needing to stop and charge. Again, never going over 65 MPH.
Here are a few questions:
1. Ride height? Assuming I should keep it on the lowest setting.
2. Chill vs. Standard? Assume I should keep it on chill.
3. Will the wheel hubcaps help once they arrive?
4. Are there any other settings I can fiddle with to increase the range?
I believe that I can possibly eliminate 1 stop by better managing which Superchargers I stop at. Thankfully I-95 has a ton of Superchargers but there are stretches where they can be scarce. As an example, Homestead, Florida is the last Supercharger before Marathon and there is 77 miles between the two chargers. If I can schedule my chargeing so as to get to Homestead nearly empty that will possibly eliminate a stop.
The other time consumption issue was with the need to drop the trailer almost everytime we charged. I got lucky on a few of the stops due to the fact that we were traveling at 3AM and was able to pull in and take up some empty charging slots. Not so lucky on the way home due to the fact that we drove thru the day.
My wife and I are 60 years old and are generally in no hurry to get anywhere anymore so doing this 2-3 times per year is a small price to pay for having an awesome truck.
Any advice is greatly appreciated.
