- Dennis
- Jul 3, 2021
- Ogregon
- Model Y
- #16
If you have tabs, the route for the power to get in and out of the battery is constrained. The bigger the battery, the worse this issue is. Sort of like the door to the movie theater when the movie ends. The bigger the theater, the harder it is to get people out one little door.Not really though.... all materials have resistance to current unless they are in superconductor realm. It is internal resistance that generates heat, heat increases resistance which generates more heat. So there are 2 ways to attack this problem. 1. Lower initial resistance or 2. Slow the increase in resistance.
Larger cells of the same chemistry and design as a smaller cell have an effective lower initial resistance or higher C for the same amount of current.
Cr=Ir/Er
Tab-less cells eliminate this issue. Like someone opening a giant rolling door in the side of the theater.
Anyhow… doesn’t matter because the rolling door comes with this bigger theater so effectively it’s the same.
