Off Road Extract Mode Speed Limit: 7.5 MPH Or 10 MPH?
MyFirstElectricTesla
SoCal
Benz
If I remember correctly I've read somewhere it's only 7.5 MPH for Extract Mode but on other thread member posted 10 MPH. My truck only goes to 7.5 MPH, called Tesla and someone said I should drive to a SC to check.
Any one confirms it's 10 MPH?
Fodderof4
CyberBeast
Have you driven yours at 10MPH in Extract?
I think that is his question…
SoCal
Benz
Yes, I know it said 10 MPH in the manual NOW. As I posted I've seen it 7.5 somewhere. And I already called Tesla and they said take it to the SC to check.
And my truck won't go to "Very High" and just stays at 7.5 MPH even I floor the pedal.
Thanks you for your clarification!
SoCal
Benz
I guess I need to add "Overland" Extract mode for highest ground clearance.
Also "Extract" & "Very High" stay at their limits 7.5 MPH & 25 MPH. I have to manually touch the "High" on screen to remove the speed limits. Are they normal?
tmeyer3
Trevor
www.meyerwine.com
Computer Scientist, Vintner
Off topic, but why would you ever want to go near 10mph in such rigid suspension modes? Extract gives very near to no flex/travel to the suspension which is very bad news at even low speeds. Just curious
A-AY-RON
TX/VA
'69 Camaro Z28, '15 Viper GT, FS-CB, '16 500 Abarth
SYSTEMS ENGINEER
Off-road/Overland/High is the highest you can drive without speed limitation. In "Very High" mode, my speed tops out between 18-22mph. Lowering to "High" removes the speed limitation once it lowers to that level.
SoCal
Benz
My "Very High" goes up to 25 mph but stays there even I floor the pedal. Does your CT automatically adjust from "Extract" to "Very High" to "High" after reaching the speed limits?
A-AY-RON
TX/VA
SYSTEMS ENGINEER
No, mine pegs the 18-22mph limit and then bogs. I have to switch to High manually, at which point it will allow accleration past 18-22mph once the "High" height threshold is reached.
