CyberFreak
CT
They're designed as sealed units basically.
Swap out, send back to factory to deconstruct for new assemblies.
Are you suggesting Tesla would use parts from the Sent-back unit for other repairs? Seems like a good way to get sued for using old parts as new. Certainly a unit with 10,000 miles on it is not the same as a brand new one. I could see negative legal implications for Tesla if they do this…
Deleted member 17810
Guest
No, but assemblies and their parts (in all industries) are recycled/refurbished/etc.
CyberFreak
CT
What use would a refurbished part have if not being used in a customer’s vehicle?
FYI Tesla does not label their parts as “refurbished” so if they were in fact doing what you suggest, it would have negative legal ramifications.
Macgyverfever
Regular Don-Won
Tn
MYP BLUE/WHITE, M3RWD GRAY/BLACK
Multifaceted IT Professional
Tesla forgot to add a third motor in mine (smh)
TeslaKen
TeslaKen
Ken
Overland Park
www.halocybertruck.com
Currently Occupied
Love your radar detector mount. Which detector and mount is it?
That is an Escort Max 360 Mark 2 and the mount is a 3D printed one I picked up from a link here and bought off etsy.. I did send the person a message about a suggested improvement (make it longer and I could use both the mirror and the mount) but I never heard back. Maybe @TickTock could help?
TickTock
Phoenix, AZ
Electrical Engineer
If you just want it longer, most slicers allow you to scale the model independently in the X,Y, & Z. So you could scale the Z before slicing and then print. I use PrusaSlicer but would be surprised if any didn't have this capability.
TeslaKen
TeslaKen
Ken
Overland Park
Currently Occupied
I will have to see if I can figure that out, the problem is that I don't have the 3D file, I bought the finished product from someone on Etsy who 3D printed it and I'm not sure that they would give me the file, hence me asking them about making a longer version but they never got back to me. If you can find the 3D file for the Escort detector I will see if I can modify it, but I wasn't able to find the actual file, just the finished result.
truck
Tesla Model X 2017 100D LR/S 2015 P85D/Cyberbeast
It’s not a software version. It’s an incorrect board on the inverter of the front drive unit on some beast units which is limiting the speed to 114mph.
My front drive unit is getting replaced because of this
this is low-key a recall
Is there a list of affected vins available or do I need to go back to the drag strip to check? ?
FlipSixThreeHole
Earth
Cybertruck, not yet produced.
Ok hear me out…
Cyber Beast launch but in reverse ?
Don’t actually do this, I don’t want anyone crashing in spectacular fashion.
scottf200
Western NC
X; immed family 3 & Y
I took the truck in a couple weeks ago because it wouldn’t go past 114. Engineering in Austin said it’s due to the board on the inverter of the front drive unit and the entire drive unit needs to be replaced.
Sounds like yours is also affected by this batch of bad boards.
I wonder if it will show up on the official service list:
https://service.tesla.com/en-US/documents?modelCode=CT
There is another Tri-Cyberbeast one out there.
Feb 14, 2024SB-24-40-0020Replace Tri Motor Rear Drive Unit InvertersOn certain Cybertruck vehicles, the LH and RH tri motor Rear Drive Unit (RDU) inverters do not meet Tesla quality standards and may cause the High Voltage Interlock Loop (HVIL) pins to disconnect intermittently. Replace the LH and RH tri motor RDU inverters.40 - REAR DRIVE UNITCybertruck
Hello4x
Indiana
Ton
I just experienced the 114 mph limit in my CB. Has anyone had a recent SC experience where the inverters/motors were replaced which increased their limit to 132 mph? I believe this will fix the vibration as well.
Guylouis
Guy
F.S. CyberBeast, XP, YP, 3P
you will need to get a new front drive unit. It’s the only fix.
