Brandon708
Brandon
Downers Grove, IL
oneupsigns.com
Cybertruck, GMC Seirra, Model X, E-Transit, F550
Sign maker
I really like that they did the light bar the same as the front headlight instead of the earlier renderings that were like the reverse light housings. It looks much cleaner that way and looking forward to seeing it at night.
jf64k
jf64k
According to the Service Manual, they are not permitted to hook it up or even remove the blackout tape from the front:
Note
Tesla employees are not permitted to connect or assist with the connection of the Cybertruck off road lightbar harness to the roof accessory jumper harness. You are responsible for using these instructions to complete the lightbar harness connection yourself.
Warning
Tesla employees are not permitted to remove the blackout film tape from the lightbar. Do not remove the blackout film tape from the front side of the lightbar.
Note
The Tesla Lightbar for Cybertruck is designed only for off road use. Tesla by law cannot install the lightbar electronics and configure the vehicle for lightbar control.
Off Road Lightbar (Mount on Windshield Only) (Retrofit) (tesla.com)
Deleted member 17810
Guest
It's pretty wild that those power points don't have an actual connector.
Diveflyfish
James
Wisconsin
2024 CyberBeast 2011 BMW 335d
Dentist
jf64k
Ok I see that but I am curious as to the underlying rationale for hands off on the wiring etc……
INAL, but it's due to the lightbar being only for off-road use. They can't enable it or let it leave the SC without the blackout tape covering it.
However, if YOU want to enable it/uncover it, that's on you.
Similar to tint: Tesla can't tint the windshield, but you can get tint installed. Still not legal even if you do it, but Tesla doesn't control that.
Or something like that, haha!!
Diveflyfish
James
Wisconsin
Dentist
Thank you.
beastew
beastew
Stew
Oceanside, NY
Cyberbeast Foundation Series
Lightbar is permantly attached to the windshield
jf64k
Operating lightbar was added "Controls > Outlets & Mods "
That's awesome!!
Thanks for sharing that!!
And congrats, are you the first non-Tesla employee/engineer CB with a lightbar??
