Permanent PCS fix
Kengineer
Kiwan
Huntsville al
Foundation cybertruck
I got a message from Tesla service about continuing delay in getting PCS parts. I told him no worries since I got a loaner and also responded that I will be hoping the fix will last a long long time. He responded back saying it is a permanent fix!
Kengineer
Kiwan
Huntsville al
Engineers aren't in the business of building "Temporary" fixes. Or, to put it another way, the past six PCS revisions were all "permanent" too... right until they weren't. :)
Yeah but maybe they know the root cause and maybe they are right this time. At least the response is positive better than response specifying hopefully.
As long as you don't drive the truck or charge it much after this service center appointment it should be permanent :)
EWELON
Rori
Wynnewood,PA
also hopefully your replacement is installed properly. one of the earlier replacements resulted in the need for a full battery pack change. but this was one of the earlier ones and it was on a YT influencers very heavily used CTs. (TesLatino) hopefully the rest of the fleet will benefit from that learning case.
Vagis9780
Louisiana
Cyber Truck
Wonder if the PCS problem is from PM motors or from not using SiC drivers?
Is there any data that points to frequent Super Charger use versus home charger being a cause for failures?
SabrToothSqrl
PA
CT Ordered | 2023 Y, X, Previous: 2013 S85, 2018 3, 2019X. 3 Wranglers, 2 Tahoes
Cat Herder
the most permanent fixes I've ever seen started as temporary ;)
[QUOTE="SabrToothSqrl, post: 30804785, member: 32364 ;) orary ;)
[/QUOTE]
All failed attempts at permanent fixes started as temporary.
