Nebucheri
Nebu
Plano, Texas
Cybertruck F S. Lexus RX450h+
I have come up with this solution, since this Valt Cargo Divider would not be aligned in the bed L Track.
I have used two L Track Hooks on both sides of the Cargo Divider and it works pretty well and strong!
Tesla Cybertruck Protip: Solution to install the under designed and misaligned Vault Cargo Divider! CT Valt cargo divider1
Tesla Cybertruck Protip: Solution to install the under designed and misaligned Vault Cargo Divider! CT Valt cargo divider2
deltaflyboy
Joe
st petersburg fl
s,y, cybertruck
pilot
I love that idea thank you. I bought one because of the 2500 spend and it's still in the box, because, like your picture I have a bed mat on top. Now I dont have to cut the bed mat to fit the cargo divider. As a side note I also bought the cargo bins and they fit perfectly in the grooves of the bed mat and dont move at all.
BillSirloin
Austin
Nice trick. I found that even without using the L track hooks, the divider holds tight when you lock it in place, even though the divider is not fitting into the actual L track. I also did not want to cut the mat or buy a new divider.
sefar
se
Missouri
Model S 100d, Cyberbeast FS
It is a warranty repair to get it to fit. I had it done this week, took about an hour.
I still had problems getting it to fit after the fix, the tech came out and showed me how to push it down to lock it in place. Not nearly as easy as the Ram bed divider was but it does hold now. I do miss the Ram one that doubled as a bed extender but can't have everything!
deltaflyboy
Joe
st petersburg fl
s,y, cybertruck
pilot
thx problem for me is I dont want to give up the bed mat. they won't warranty fix it with the bed mat on. this solution is perfect for me
'23 MYLR, FS Cyberbeast 280xx
So... you need tools to move it. I've ordered a divider, and I hope they've fixed the issues so it works right.
Tdang75
X5
I was able to make the cargo divider work with the bed mat by cutting it and folding one piece to keep the bed protected when the divider is removed.
Tesla Cybertruck Protip: Solution to install the under designed and misaligned Vault Cargo Divider! IMG_1504
Tesla Cybertruck Protip: Solution to install the under designed and misaligned Vault Cargo Divider! IMG_1508
Tesla Cybertruck Protip: Solution to install the under designed and misaligned Vault Cargo Divider! IMG_1509
Tesla Cybertruck Protip: Solution to install the under designed and misaligned Vault Cargo Divider! IMG_1500
Tesla Cybertruck Protip: Solution to install the under designed and misaligned Vault Cargo Divider! IMG_1510
Cyber_P
Alabama
AWD Cybertruck
The 3d printed inserts worked well for.me. Extremely.tight fit.
"Within spec" per my service center. Even showed them the modification to show it was not.... Within spec.
" Nothing we can do! Seems like it works now. Have A good one. " - SC essentially.
rudedawg78
Ernie
South Carolina
Oh wow, great fix! I have the same bed mat as you and haven't had any luck installing my divider yet. I am going to purchase a couple L track hooks and try this!
Thanks for posting.
rudedawg78
Ernie
South Carolina
I was thinking of cutting my bed mat like you to make the divider work, but like the OP and others state, I don't want to cut and damage the mat.
wh1t3rbb1t
Cybertruck Founders Edition
Cybersecurity
Even without the bed mat, mine doesn’t fit at all and doesn’t stay in place ?
Jack27
Randy
None
There is a thread on here that shows a great way to fix the issue and it worked for me. You just unscrew the ends and take out the plastic guide it gives you little play of movement on both sides and just enough to be able to clip them in
Mattkalin
Matt
SW Michigan
2023 F350 Superduty , 2023 Model Y AWD
Someone needs to make a dedicated thread post to this and make it a Sticky!
