SlegMD
- Apr 24, 2023
- Arizona
- Lexus
- Occupation
- Medical
Is stability of the temperature important to you before you do this? I’m curious if the vault has any insulating properties. Might check that first, run a heater with a remote thermostat?I want to remove the rear window on my Cybertruck so that there's a way to cool the vault from the cabin HVAC (Camping Mode). It would also provide a pass-through from the vault to the cabin that would be useful when sleeping in the vault. I examined the way Tesla mounted the glass panel and it looks like it can be removed from the vault side with not much trouble. It involves removing the plastic applique (photo) to expose the confinement elements. It also appears that the glass panel is not a structural component (it does not appear to be supporting the glass roof).
It looks to me like an aftermarket slider replacement window could easily be designed to replace the fixed glass panel. I'll follow up when I have more information on the removal.
I think the reason Tesla didn't design their own slider was to avoid the liability of someone getting injured. Although the tonneau cover will retract if it senses resistance while closing, a child's hand/fingers could be badly hurt if caught
in the path of the cover while being closed.
If anyone has experience removing the rear window I'd be interested in hearing from you.
If not, I am a fan of an opening back window myself, just not sure if it’s worth running the HVAC.
