raww1023
NJ
2025 CT Beast
I had the same exact issue everyone here is describing.
I took it in for service and made sure to note the problem clearly. I also went on a test drive with the tech — he sat in the back seat and immediately saw what was happening. After that, he brought it back in and explained the fix.
The issue was that the rear glass has a very slight bow (possibly a manufacturing tolerance thing). Their fix was to add a small piece of weather stripping to the rear gasket, which pushes the glass out just enough to seal properly. They also recalibrated everything, but the tech said the gasket adjustment is what actually solves it.
What was interesting is that this only happened in colder temps. When it was around 40–50°F and above, I didn’t notice it. Below that, the issue showed up. The tech also mentioned they had another Cybertruck with the same problem either the day before or the day after mine.
End result: problem solved, no charge.
My advice — just bring it in for service and make sure they ride with you so they can see it firsthand.
Hope that helps someone 👍
Sxksxk
Sharif
Minnesota
Cybertruck AWD Foundation series
I had the same exact issue, and dropping the rear windows SLIGHTLY greatly reduced the noise.
I installed the aftermarket door seal kit, and it stopped completely without having to fiddle with window positioning.
Which kit?
Protondecay123
Jim
Cyberbeast FS
Thanks for a clear explanation of that. I figured lowering the window a “ smige ” was reality it better somehow. I have it with both rear doors.
What kit is that?
bdesign
Ohio
FS Cybertruck AWD
Update - I'm in a loaner CT while my PCS is being replaced.
The passenger rear window noise on this loaner is much worse than mine (unbelievably loud), and I doubt the kit I used on mine would help.
Mine was generally annoying; this one is loud to the point of thinking the window is partially open or something.
pae1andonly
Paul
2024 RAM 2500
Opened the passenger front door yesterday. Quite a bit of snow jammed into the rear corner. I'm tempted to find something to seal low on the door as well.
RayzorBEV
Electric Bum
At highway speeds my wind noise was pretty loud. All windows were in the upmost position. And then I tipped the rear windows to drop slightly and the wind noise was gone! The windows sealed the wind and road noise out perfectly by dropping the windows lightly. Crazy!
It worked on all 3 of my Beasts. It so weird and counter intuitive but whatever works!
