Roof rack options
C3y3ber
Randy
2018 Model S 100D
Wraven
Doug
San Antonio Texas
Foundations CyberBeast, M3P
Not sure I have seen any *customers* with roof rack rails of any kind yet. No reports I have come across that highlight either product in real world use as of yet.
Deleted member 17810
Guest
The UP INVINCIBLE® HD Roof Rack provides unlimited potential for mounting to the Cybertruck’s roof and over the truck’s bed. The four heavy-duty roof rails bolt directly onto the Cybertruck’s OEM attachment system for easy installation. The heights of each roof rail are unique and specifically designed to orient carried items in a flat plane allowing flat panels to easily attach in a straight plane, a function not possible with Tesla’s roof bars which do not create a flat-pane, straight line orientation, despite what the truck’s design may suggest.
Delusional
Phil
Pittsburgh
F-150
Construction
Clicked on the link for the "invincible" roof rack, and they have changed the name to "invisible".
Sooooooooooooo why are the rear racks not elevated.
If you put a kayak on there in the current configuration, a long piece of wood, etc. It is going to tear itself in half at over 50 MPH as it will be at a 45 degree angle.
Need to try to get the racks close to level to reduce wind resistance.
sylvius
SE PA
CyberBeast FS ordered
I’m not so sure how useful the roof rails will be on the CT. Presumably you’d mostly want to put things on them that don’t fit in the bed like kayaks or roof boxes. With the angle, they will have a lot of drag pushing up on the bottom of them and I feel like the attachment mechanism is designed more for a shearing force than a pulling force. It makes me picture that minivan you see on the freeway with a mattress on the roof that is folding back from the drag and eventually flies off. Am I missing something? Maybe a few pairs of skis would be ok but those should mostly be fine in the vault anyway.
Why are you assuming that the wind stream is straight? Look at some of the examples and you may see that the wind stream follows the down tilt of the tonneau cover.
BannedByTMC
NYS
Something like a kayak would not be a problem since it's an aerodynamic, (hydrodynamic) shape anyway but a piece of plywood could be an issue if it went past the front windshield. However a standard 8ft plywood would not stick out that far and should still be in the laminar flow of the vehicle.
At low speeds (sub 40mph) you would likely be ok, but if hauling anything of size (over 8') the nose up drag created would be significant, especially at that much of an angle. Surfboards, kayaks, boats, SUP boards, even lumber would be under a tremendous amount of stress so a rack with the back elevated will be needed for people using racks often, and at higher speeds with longer objects imo.
cofree
colorado
tesla model 3 LR dual 2018
I would expect the airflow near the tonneau to roughly follow the tonneau cover, as there won't be much air coming through the tonneau (although some may go around).
Indeed someone has made an approximate rendering of the cybertruck and run it through CFD: https://insideevs.com/news/385328/tesla-cybertruck-aerodynamics-explored-in-detail/ and that also suggests that provided the object is at least a foot behind the peak of the roof there should be very little force on the object perpendicular to the surface of the tonneau.
Compare this to a model 3 with a Skybox 21 on top (i.e. our car last season) where the windshield is forcing a huge amount of air directly up into the skybox.
Now if the object extends to (or forward of) the peak of the roof of a cybertruck then yeah, I would expect a bunch of airflow there (apparently 88mph of wind for a car at 65mph for the Cybertruck) and much of that is perpendicular to the object.
And a note for everyone else... there is a difference between the words "flat" and "level". The Tesla tonneau when closed is as flat as the tonneaus on other trucks. It isn't level but it is flat. Some posts on this thread are confusing to anyone who does know what these words mean.
Cybertruck 1974
Everywhere
Built my own. Couldn't wait. These so-called metal fab start up guys are just not capable.when needed, push from back support bar up and rack levels to grade with side support legs engaging at horizontal position. I've created the first and have all parts list if interested. Done. Painting this one matte black same as trim.
Tesla Cybertruck Roof rack options 20240513_181224
Roger@CYBERTRUCKco
Roger
Poway, CA
manufacturing
just launched Heavy duty crossbar system last weekend, use one for top to mount lights, or all 4 of you have the need, $369-399 each. Also has a Rooftop tent mounting kit, molle panels etc. there is also a 20% off coupon…
Tesla Cybertruck Roof rack options IMG_5781
cardad
Kelvin
Moab
R1S, R1T, Bronco Raptor
Hard to tell how your leveling works from this picture.
Cybertruck 1974
Everywhere
Yep, it's adjustable heights let's me put the Rack to whatever level that's needed. Flat to top of truck or flat to earth for the shade of the canopy to appear. #done. #homegrown
Tesla Cybertruck Roof rack options 20240514_204812
Tesla Cybertruck Roof rack options 20240514_203752
