Same.Turning at slow speed sharply can cause this rapid thumping, sounds like a buckling sound along with vibrations in the steering. It stops after half a second and otherwise I don't notice problems. Has anyone seen an explanation?
Is it tied to the height change for easy entry? That can load up the tires and suspension causing scrub.Same.
I've experienced this 3 times, but can't replicate it on demand. It seems to occur when parking/after parking and then I turn the wheel a little more. It's a loud rubbing noise coming from outside the truck, but I can't determine what's causing the sound.
I don't use the easy entry so we can rule that out.Is it tied to the height change for easy entry? That can load up the tires and suspension causing scrub.
Yep, doing some extremely light off-roading recently and noticed it quite a bit, only at full turn left or right and at slow speeds. Didn’t sounds right to me but honestly I disregarded it since it’s not something I’m noticing all the time, figured it’s just from being off road. I was also in off road more in “very high” mode.Hello fellow CyberTruckers,
I took possession of my CyberTruck a few days ago. When at low speeds, the steering has a rubbing/grinding sound. Do other people hear that on their trucks too?
Thanks,
Kim
