Secret Micro USB Port Inside Overhead Trim [TCU Connector]
truck
Tesla Model X 2017 100D LR/S 2015 P85D/Cyberbeast
Anyone know what this is for? Diagnostics perhaps?
Tesla Cybertruck Secret Micro USB Port Inside Overhead Trim [TCU Connector] IMG_8459
Tesla Cybertruck Secret Micro USB Port Inside Overhead Trim [TCU Connector] IMG_8460
Shadowmite
Denver, CO
FS CT, 24' MYP
Is that the area with the telematics module? Could be diagnostic connector for the modem…
gtgarner
Garlan
Cybertruck ands P3D
Thats the port they utilize for the Ethernet Bus (High Speed Data BUS).
Parts Catalog
Don't plug anything into it - unless you want to brick your vehicle. This Ethernet loop is NOT forgiving to foreign objects as the CAN bus is on other models.
Parts Catalog
Nah, that's the TCU which isn't an Etherloop node (but does have a 2 wire Ethernet connection)
The Ethersnoop diagnostic port is an RJ45 by the MCU and not in the safety critical main backbone.
Tesla Cybertruck Secret Micro USB Port Inside Overhead Trim [TCU Connector] SmartSelect_20250825_041615_Firefox
Tesla Cybertruck Secret Micro USB Port Inside Overhead Trim [TCU Connector] X0675-1-COM
What are telematics? And why do they need a control unit? Also, what in the world is an ethersnoop etherloop node?
Asking for a friend.
Tesla Cybertruck Secret Micro USB Port Inside Overhead Trim [TCU Connector] IMG_5525
Telematics module: handles.the cellular (and wifi?) connectivity
Etherloop: the main high speed digital backbone of Cybertruck . It it 2 wire automotive Ethernet and runs in a ring/loop so, even if a link is broken, all modules can still communicate .
Left <-> MCU - FSD - Right - Rear <-> Left
Ethersnoop: the diagnostic connector to watch Etherloop traffic, fed from MCU/Gateway
Thank you. My friend says he’s very grateful.
Also, it quite possibly could be used as a tap for retrofitting digital mirrors 😉 (something I was really hoping the truck would launch with).
So after an extended nightmare adventure lasting months with the s92 mirror, the best source for these seems to be the powerfeed that has a clip on the drivers side inside the autopilot camera housing.
would be cool to use something that didn’t require an extra little harness or soldering though.
gtgarner
Garlan
Cybertruck ands P3D
Mongo, do whatever you want playing around with this port.
There are 3 CT's here in the service center due to a few people playing around with it. $3.5k each one so far. The internal Steer-by-wire unit is dead on each occasion.
Opens are rarely a risk on a loop. However short it out with a cheap amazon micro phone cable if you want - play at your own risk. If your steering wheel goes limp after a short to this port - please don't' try to fix/reverse it.
Please 3rd party vendors - leave this port alone and continue to use the data/power port behind the lower passenger's kick panel. - Its safe to both opens and shorts and good for data snooping.
But - do what you want.
Cactusrick
Richard
AZ
CyberBeast, MYLR, EXT, 380SL
retired invest
Took off both mirrors a few months ago for a trial period but decided I don't need them. They block vision IMO. It sure looks better,
Tesla Cybertruck Secret Micro USB Port Inside Overhead Trim [TCU Connector] 20250704_135804
I love the look of your car without them Rick.
