Show us an accessory we’ve never seen before! MFZ Challenge thread.
CodeSection
Code
Arizona / Colorado
2025 Kia EV9, 2018 Toyota Sequoia, 2020 Toyota 4Runner, 2006 Nissan Xterra
@hemiarch, figured it out. If you only have an iPhone and no computer, you can follow the steps below to capture online videos that cannot be saved via other methods. It works, but since it has a couple of steps involving switching screens, it is a pain.....but better than nothing.
Tesla Cybertruck Show us an accessory we’ve never seen before! MFZ Challenge thread. 1763505793854-5o
Nice! Thank you
Black306
Sacramento
‘26 PAWD CT | ‘23 M3 RWD
@hemiarch when you put the video in your OF ... err, Instagram account, don't forget to tag me. 😉
Of course of course. Was just trying to send it to my wife who is a huge Back to the future fan.
bkellisimo
Blake
Michigan
Cybertruck Foundation AWD
Sales
For those interested, there is unlimited potential to build off the L-Track rails using bolt adapters like this:
US Cargo Control L Track Double Stud Fitting with Bolt Thread, Use with L Track Rails in Your Truck Or Trailer to Create Instant Tie-Down Anchor Points, Working Load Limit of 1,333 Pounds, 4 Pack https://a.co/d/2kuQkph
mine has a switch as well but it doesn't work. i reached out to the manufacturer and he states it only works for ICE vehicles. EVs will always be on according to his response.
I just hooked mine up.
It does shut off after a time, but I haven't tested to see if that is due to the adapter performing better than its spec, or the Cybertruck shutting off the OBD power.
Either way, if you want it to shut off, it does.
Unlikely the latter unless you’re consistently drawing above 5 amps I think. Possible, but not likely.
I mean it shuts off after you turn the truck off and exit. It powers my camera monitor just fine.
Or are you saying there is a vehicle off 5A limit on the ODB port?
Roughly 5 amps even then it seems to be a digital fuse because it resets itself. I was able to run a continuous 54w battery charge off of it for days without issue.
These are my favorite solar panels by a mile for camping and are a SCREAMING deal right now at $329.
They make every bit of the rated 600w. A pair of them is perfect for the delta2 max or delta 3 plus and 4 of them are ideal for the delta 3 pro. Two in series for the high voltage side and two in parallel for the low voltage side.
https://a.co/d/c2eCxrZ
Anybody else got any screaming deals for BF?
Cybertruck 1974
Everywhere
Kammock awnings on all three sides, rear awning folds down so I can carry long loads on rack and the roof rack lowers flat to truck, cause it looks cool, spare tire swing arm, air compressor and a rear water cannon for the tailgators.....or to just wash up are a few things I built.
Tesla Cybertruck Show us an accessory we’ve never seen before! MFZ Challenge thread. truck
Tesla Cybertruck Show us an accessory we’ve never seen before! MFZ Challenge thread. 20251005_130523
Tesla Cybertruck Show us an accessory we’ve never seen before! MFZ Challenge thread. 20251005_130225
