- JB
- Nov 22, 2019
- Australia
- Cybertruck
- . Professional Hobbyist
- #1
There was some discussion on various threads about using slipstreaming or drafting to extend EV range. This is when vehicles follow each other closely to minimize aerodynamic drag and therefore reduces energy consumption. I thought it would be interesting to discuss this in more detail, and maybe envisage ways to make it work, after considering the risks involved.
The benefit for EV's range improvement varies primarily because of:
As can be seen in the diagram above the effect actually assists all vehicles in the convey, including the front one. The reason for this is that the first vehicle produces a slight vacuum behind it, which reduces air resistance and entrains air for each following vehicle, until the last vehicle in the convey that experiences a slightly higher air resistance as the airflow reconverges behind it and creates turbulence. On a single vehicle, this rear reconvergent turbulent airstream also creates drag, and that is why the first vehicle in a convoy also experiences a drag reduction by that amount.
This technique is also often used in sports, from Nascar, F1 to cycling like Tour de France, and even skateboarding etc. Similarly sailing uses wind shadows to slow other competitors. It's important to remember that the effect is aerodynamic, and as such the aerodynamic shape and size impact how well it performs. The figures I'm using are not accurate to all Tesla models but would fit with a CT given that it is not as aerodynamic as the other models.
In the scenario to improve EV range, there is a possibility to increase CT range by up to 40% depending on how close the cars travel together. This depends on how close the vehicles are, with closer being better, but reasonable results up to 10% at even 30m(100ft).
The intension here is to use similar if not identical Tesla vehicles to operate in the convoy. The reason to limit the initial rollout of this to a Tesla is because the integrated FSD hardware can provide substantial benefits and safety margins whilst operating in this configuration, and the slipstreaming mode could technically be incorporated in a OTA update. This mode would only be available on fairly straight main roads and highways, possibly only mutilane roads, with the right driving conditions, based on weather and traffic conditions.
Let me address the main risk of this setup, and the one that will likely be most commonly perceived as a problem.
That is braking distance versus following distance.
Now braking distance on a Tesla is in the low 30m (100ft) range, depending on speed, and at that distance a 10% range improvement could be realized. Ideally, we would reduce that distance further, but this means that the following vehicle(s) will not be able to stop in time if the vehicle in front comes to a abrupt stop. I say abrupt stop intentionally, because any controlled braking maneuver could be matched, within 10-20%, by any following vehicle. An abrupt stop would only occur should the lead vehicle hit something stationary, otherwise an emergency braking maneuver by the front vehicle could be matched by any following vehicle, within a distance safety margin.
The problem with normal human driving is the control loop time between seeing the vehicle in front braking, assessing the rate of deceleration, then modulating how much to brake as to avoid collision. In the case of the convoy it is important that the FSD and the braking of the first vehicle instantly triggers the following vehicles to brake as well, effectively closing the control loop time to ms instead of seconds. That way all vehicles act as one, essentially becoming vitual trailers of the vehicle in front, and the front vehicle FSD can relay commands down the line according to conditions, to either increase of decrease the follow distance.
The question is how do we get the front Tesla to communicate this with the following vehicles without adding any hardware. We could go down the Bluetooth, that is range limited and won't reach to the end of the convoy. Mobile cellular network is to unstable and high latency and dependent cellular towers. That leaves the vehicles wifi connection. This also has limited range, but could be used in conjunction with a mesh stack that can repeat the signal from one to the next down the convoy at low latency, and reasonable reliability. At some point a dedicated telemetry radio signal might be useful.
After thinking about a solution for this for a while I realized the solution might actually be simpler than that in that Tesla vehicles already have independent light control via it's Canbus lighting architecture. Technically this means that by switching the rear lights on and off in pulses, the front vehicle can convey braking and distance information to the following vehicles. Ideally this could be done by controlling the PWM cycling of LED drivers meaning that the coding would be imperceivable to the human eye, but easily picked up and translated by the FSD cameras and at low latency. The encoding could be by multiple lights simultaneously, or at least the three braking lights. The update to read this would be embedded into the FSD.
Following on from this, I think Tesla should possibly consider this for non-convoy driving, even manual driving as well, and to possibly extend on this by using situational awareness of the road ahead to influence other cars driving behind them. This could for example be used to combat traffic compression waves, assist in merging lanes, or to allow EMG vehicle passage and the like.
What other ideas or comments do people have regarding using CT in a convoy or automated traffic management capacity?
- how large the vehicle in front is in comparison to the one following
- how close the distance is between vehicles
- how aerodynamic each vehicle is in the convoy
