RichieBNYC
So you got them to fuss with the seal under the appliique. Nice!
I got mine done yesterday by the Jacksonville FL SC. Everything they did so far looks good and it is working fine. No more leaks in the vault ether (I tested). I had much water leaking in before fix. Pics of invoice also for this fix. They started fixing at 11:00 am and finished at 1:00 pm.
Before slat fix done:
After slat fix done:
Water intrusion before fix:
Water intrusion after fix (pretty much none):
Invoice for this service work:
Tesla provides an invoice and everything was on it that they did in detailed. I included it in my post above.How did you get all the details of the work done z you ask them or is in the app . I have a feeling I had the extra slat out in but none of the other stuff
thanks will look into it .Tesla provides an invoice and everything was on it that they did in detailed. I included it in my post above.
big difference to work done on my truck with similar leaking problem ( still leaking )thanks will look into it .
Now, that's a good service tech to check and replace the seal on the appliqué!I got mine done yesterday by the Jacksonville FL SC. Everything they did so far looks good and it is working fine. No more leaks in the vault ether (I tested). I had much water leaking in before fix. Pics of invoice also for this fix. They started fixing at 11:00 am and finished at 1:00 pm.
First you should remove the invoice that has your personal info on it from your post.Big difference t
what next go back ?
This is similar to my experience. I just washed my CT yesterday and the bed had a large amount of water in it. This was after I've gone through the tonneau fix, which was with a Beast BTW.I brought mine to the nearest SC yesterday, Sherbrooke, PQ. They told me they had never heard of this issue.Then they told me they all are like that. When I showed them the sales inventory did not look like that, they said it was because only the Cyberbeast has tonneau cover that covered the entire vault, other cybertrucks tonneau cover almost cover the vault. Lies piled upon lies. It took them an hour and a half to fix nothing.
My SC added the extra slat and titled it as “slat rework.” So they are doing fixes. No reason for anyone lying here about itThis is similar to my experience. I just washed my CT yesterday and the bed had a large amount of water in it. This was after I've gone through the tonneau fix, which was with a Beast BTW.
Either Tesla is full of liars or this forum is full of liars. I can't figure it out.
