RonSol
- Ron
- Feb 19, 2020
- Archbald PA
- MY LR / CT / 3P
- Occupation
- Systems Engineer
The ball joint above the front tire has a 4 sided flat that is for a wrench during assembly/ disassembly. Directly above the tire. It’s position relative to the tire is fixed but when you start to add taller tires the distance between the tire and the bolt decreases. You could just cut with a grinder.
