- Crissa
- Jul 8, 2020
- Santa Cruz
- 2014 Zero S, 2013 Mazda 3
You use some of the range in the battery, and only run the generator to recharge it when you need to.
Mostly, there will always be a place to charge within range. There is never the case that there's no power for hundred of miles, so you just drive to somewhere and charge up. Then drive back home.
You can also, like the poster above, choose to pull the breaker and charge the truck with your generator or solar.
Houses always use more power when you're there than when you're not.
