TheEther
Kentucky
[This post assumes your ventilated seat fans are working correctly]
Updated 2/20/2026.- See this link for an internal look at the possible seat cooling issue and huge thank you to the poster on X for this!
Update 8/20/2025 - The Cybertruck Ventilated Seats work by vacuuming air into the seat rather than blowing air out of the ventilation holes. Thanks to those that set us straight on that.
I've found the CT ventilated seats like many other posts on here to be lack luster, I hear the fans running like heck and when I put my ear up to the ventilated seat holes can feel and hear the air moving but when I sit down, it feels good for a few minutes then, very little cooling. I sat in a Cadillac Escalade the other day and noticed the ventilated seats were impressive. Which made me realize the flaw in the CT seat ventilated design.. I've noticed in my Cybertruck if I arch my back and create 1/4" - 1/2" of space between my back and the seat I get a LOT more airflow. Night and day difference. Then it hit me....
Notice the Cadillac Seat design around the ventilated mesh:
Tesla Cybertruck Ventilated Seats Issue Fix / Workaround - They're better than you might think Screenshot 2025-08-17 at 5.40.17 PM
There are multiple diagonal and horizontal channels for airflow in the Cadillac design. The ventilated seat fans need to be able to get air around you and away from your body. The Cadillac design does that with its quilting valleys and horizontal valley in the middle. Read on..
The issue and the solution:
The Cybertruck doesn't have channels for airflow built into the seat.. It's flat as a pancake. When you're sitting in the seat, your back (especially if you have a larger frame) is literally sealing off all the ventilated holes with your compressed clothing/body. It can't do it, and thus.. lackluster performance.
No where for the air to go..
Tesla Cybertruck Ventilated Seats Issue Fix / Workaround - They're better than you might think IMG_8153
For Tesla to fix this, they need to redesign the seat back with quilting or channels, but we don't have that right now, so...on to the next best thing. We need space.
This is the working solution I've found (so far) which is NIGHT AND DAY different in ventilated cooling performance. It creates that gap between your clothing and the seat needed for airflow, that "ahhhh" feeling I'm looking for without sacrificing comfort (much). I can take them off in the winter when they're not needed.
See the amazon link below (not affiliate). It isn't super elegant, it's simple, (looks better in person than pictured here) I'm still looking for something snazzy but this solves the problem 100% for now making my life much more comfortable as the summer winds down here in the mid-west..
AMAZON - 3D Air Mesh Breathable Vented Car Seat Cushion
What it looks like in the truck: (It's black, the flash makes it look dusty but it isn't)
Tesla Cybertruck Ventilated Seats Issue Fix / Workaround - They're better than you might think IMG_8152
I hope this helps you understand why the ventilated CT seats perform poorly. it isn't the ventilated fan that‘s the issue, it's the flat seat design, your body blocks the air flow off rendering it useless. Tesla, if you're reading this, I'd gladly pay for a redesign..
What I've tried that hasn't worked so you don't make the same mistakes:
These basically cut off all airflow, but looked decent.
AMAZON - Auto Newer Luxury Breathable Car Seat Cover
These also cut off all airflow, I was trying a beaded design. I may try just a bead only version next. These had a thin fabric backing that again sealed off the vented holes.
AMAZON - Beaded seat covers for cars - Breathable
Tesla Cybertruck Ventilated Seats Issue Fix / Workaround - They're better than you might think Screenshot 2025-08-17 at 6.21.32 PM
Tesla Cybertruck Ventilated Seats Issue Fix / Workaround - They're better than you might think IMG_C9DFA4A2C94D-1
[This post assumes your ventilated seat fans are working correctly] I've found the CT ventilated seats like many other posts on here to be lack luster, I hear the fans running like heck and when I put my ear up to the ventilated seat holes can feel and hear the air coming out but when I sit down, it feels good for a few minutes then, very little cooling. I sat in a Cadillac Escalade the other day and noticed the ventilated seats were impressive. Which made me realize the flaw in the CT seat ventilated design.. I've noticed in my Cybertruck if I arch my back and create 1/4" - 1/2" of space between my back and the seat I get a LOT more airflow. Night and day difference. Then it hit me....
The Cybertruck doesn't have channels for airflow built into the seat.. It's flat as a pancake. When you're sitting in the seat, your back (especially if you have a larger frame) is literally sealing off all the ventilated holes with the system trying to push air into your compressed clothing. It can't do it, and thus.. lackluster performance.
I hope this helps you understand why the ventilated CT seats perform poorly. it isn't the ventilated fan that the issue, it's the flat seat design, your body blocks it off rendering it useless. Tesla, if you're reading this, I'd gladly pay for a redesign..
Thanks. Ordered a pair to try
TheEther
TheEther
Kentucky
Let us know what you think, there’s a couple of different variants of this 3-D mesh material as seat cushions on Amazon. I may order some of the other ones as well. It’s compressible, cushioning, definitely has an odd feel to it, but it does its job well by creating enough space for air to flow.
I ordered the set that I showed because I suspected I may not need it for the seat just for the back, but I tried that today with and without the seat cushion and I did get more airflow in the seat with the cushion on. I get about double the airflow on my back than the seat, but that’s what I want anyway most of the time.
koolio
Greater Boston, MA
Interesting, and great detailed post!
My wife’s ‘24 Model 3’s ventilated seats are really good and it Durant have the diamond pattern like the Cadillac seats. I wonder what is different between the two systems/seats…
That Beast Mode
Phil
New Jersey
I think the other models push out air from the AC system while the CT pulls air in - which is why everyone is complaining about it.
That Beast Mode
Phil
New Jersey
Seriously though, what’s the issue with something like this?
https://a.co/d/cbvU1g9
Is it just that you all don’t want to go full cab driver?
Don’t think I’ve ever even sat on one. Are they comfortable?
That thing looks like it comes from the factory smelling like cigarettes and Dorito crumbs.
That it does, but I’d tolerate something like it temporarily in the summer if it means legit cooled seats.
I live in Phoenix so a bit of an extreme circumstance.
TheEther
TheEther
Kentucky
it doesn’t have to have a diamond pattern it just needs to have something that allows the air to escape around you. I noticed on a Chevy Tahoe. There were small little than almost like wrinkles between the holes and that worked as well. My brother has a 2025 model Y that has noticeably better cooling. I didn’t pay close attention to it last time I sat in it though.
TheEther
TheEther
Kentucky
Oh, I never said it was pretty.Truly, I will use something else if I find something that works as well.
TheEther
TheEther
Kentucky
The only thing I can think of is, are there airbags in the seats? I was thinking more about the mass of the beads in an airbag deployed scenario, should work well also. Worth a try.
