MikeFromHolland
Holland, Michigan
Designer
I finally found a way to make the bed of CT waterproof! After trying several methods of seals, I found one that can snugly fit in the existing channel and cover the gap. See pics and search on Amazon for the seal product. Totally works even through the carwash.
Tesla Cybertruck Waterproof your bed vault - how-to DIY IMG_2227
Tesla Cybertruck Waterproof your bed vault - how-to DIY IMG_2041
RustyEdges
Brandon
Long Island
2024 FS
Check Collection and whatever else pops up!
Nice find! Is that near the tailgate or near the roof?
Musicurry
Lance
Washington
Cybertruck, Telluride
Finances
Can you redo your pictures please??!! I can’t tell exactly what you’re trying to show because of things on, or around, the truck.
Hohenzollern
Matthew
2025 CyberTruck AWD - 2004 Infiniti G series (Original Owner)
You can ask a service center to add the extra slat. It is a laborious procedure though. If you are very far from a Service center this solution here would do.
SCTesla
22 Model S, 24 CT
The extra slat doesn't make it more or less waterproof. It's the seal before the slat. Mine is "missing the slat" and I've made mine completely waterproof is new weather stripping. Those holes don't feed into the bed.
J.Graham
BC
FS AWD & Model Y LR & 993
Can someone post a link? Can’t find it
Docedward
Nashville
Non-FS 2024 AWD
Ai
Is that the back by the tailgate? Hard to tell but looks like it. Mine is perfectly sealed there but leaks at the roof slat. Told them about it in the many 30+ days at SC-it was within spec but is missing the slat. So she’s moist when it rains and flat out wet after a car wash.
Liberty1
St Petersburg, Florida
2025 Cybertruck AWD
This is great. It looks as though that new weather stripping piece is installed near the wide trim near the apex of the truck on the top/front end of the bed, but the photo could be of the trim that runs along the top of the tailgate. MikeFromHolland Can you please confirm? Also, how does it install? Is it screwed into place?
Hohenzollern Can you please give some detail on this? Can one order an extra slat from the service center and have them install it and, if so, is this something that you think all service centers are aware of or is it something that you twisted someone's arm to get done?
Patriot
Denver, CO
2020 M3, 2024 Jeep 392, 2024 FS CB
I'm surprised that seal fixed the leaking for you. Most posts I have seen on here indicate that the problem is the seal behind that, close to the window that is the problem. Tesla has a service bulletin where they will install another slat to cover those holes and make it look more finished, but as SCTesla said, that doesn't fix the leak. Someone on here posted a video showing how they fixed the leaking with an inexpensive seal from the hardware store placed under the applique near the back window.
Mal
Mal
WA
Foundation CB "Rocinante"
Yes, for me the leak was where the roof glass met the aeroflap. Easily tested by opening the tonneau and pouring a glass of water on the roof glass. I could see it pour in before it got to the aeroflap. I fixed it for months with electrical tape, and then 'upgraded' to windshield seal tape.
This was after two attempts by the service center.
NEK2MO
Bay Area, CA
Model 3, Model X, Cybertruck
Where exactly did you stick the rubber strip? Thanks!
Flex3269
Tony
Model S
Entrepreneur
How was this installed? Looking at your photo and the photo on Amazon, it looks like the adhesive side is supposed to be facing down?
If that’s true, what is it stuck too?
