Where is your charger installed?
Haoooc
Austin
Called SC and they told me likely I will get my beast next month!
Now I am thinking a practical question, where should I install the wall charger? This is my first EV so I don’t have any charger yet. I can install it in my garage but I will likely not park my CT into the garage. I can also installed it outdoor so easy to use when I park on the drive way, but any concern about security or safety?
I am wondering where most people install their charger? I can’t find much discussion here.
CyberVeteran
2024 Tesla Cybertruck
Health Care
My garage has ample room for my truck, so I installed at the front of the garage nearest to the garage door. I have seen people install exterior chargers, it is doable. But if you are concerned about security you can have the charger installed near the garage door and have the truck backed up near it, to route the charge cable so that the garage door can close while the truck is plugged in. Not sure how much copper is in the cable, but a vandal will vandalize....
akenis
Andrew
FL, USA
23 MYLR and (Apr-Jun CT AWD)
Pilot
Parking in the garage is a pipe dream for me.
Have Y now with WC installed in front of garage.
Don't really need second charger, but mostly free. Will install outside on other side of garage door.
Tesla Cybertruck Where is your charger installed? 1000001285
Mine is currently loose from the wall because we're rebuilding the carport, so it's sitting on top of a tub.
We don't really worry about copper thieves out here, though.
Balthezor
Ron
PA
Just curious what your RN number is and when did you get your VIN
SteelMyHeart
This the setup I have. It works great.
To the OP, also consider where your electrical panel is as the distance from that to the charger install location is more costly the longer the distance.
SGAstros
Ryan
St George, UT
Ram 1500, GR86, Bronco
Tech
This is my first EV too, and I just had a guy pull power off an RV receptacle I had on the exterior and bring it in garage for my truck. It’s 240v 30amp, and I just use the mobile charger that came with the truck. Charges plenty fast for me.
Tesla Cybertruck Where is your charger installed? IMG_9086
Tesla Cybertruck Where is your charger installed? IMG_9087
If thats the case then i think this is the way for me
I run my own wire. Won't help you with Powershare install cost much, but... Electricians usually like it when you do the part where you're contorting into small spaces for them ^-^
Haoooc
Haoooc
Austin
Thanks, it is a good idea to rout the cable out.
Haoooc
Haoooc
Austin
my RN is 11279x and I ordered on 12/30/2023. I haven't got my VIN yet, but the service center gave me a rough estimate which likely to be next Month.
